This User Manual and Reference Guide is a detailed guide to using all aspects of HLS. It is currently under significant development.
To quickly get up and running with a sequence, you may want to look at the HLS Getting Started Manual.
Due to the rapid development of HLS, the links that follow will contain, in parenthesis, information that can help the user with a quick visual inspection:
- 12Z: The page is up to date with the latest version of HLS.
 - R: The page is currently under significant revision.
 - CN: Content is needed to complete the page and it currently contains very little information.
Getting HLS
Download and Installation (12Z)
Upgrading HLS (12Z)
Creating a Sequence
HLS Sequence Creation Wizard (12Z)
Time Resolution (12Z)
Channel Management
Setting up HLS Channels (12Z)
Advanced Channel Management (12Z)
RGB Channels (12Z)
Configuring Display Groups (12Z)
Sticky Channels (12Z)
Segment Channels (12Z)
Display Preview
Creating a Display Preview (12Z)
Creating Basic Effects (12Z)
Adding and Using Beat Tracks (12Z)
Setting Defaults for Effects (12Z)
Creating Chase Effects (12Z)
Mirroring Effects (12Z)
Fill Effects (12Z)
Submaster Lighting Channels (12Z)
Sequencing with RGB Channels (12Z)
Custom Effects (12Z)
Creating a Library of Group Effects (12Z)
Creating a PixelPlane (12Z)
The PixelPlane Editor: Creating Effects (12Z)
Using Nutcracker with a PixelPlane (R)
Fill Channels (12Z)
PixelPlane Transitions Using Lighting Channels (12Z)
Drawing a PixelPlane in the Display Preview (12Z)
Facial Animation
Facial Animation (CN)
Sequence Playback
Sequence Playback (12Z)
Sequence Output
Hardware Configuration (R)
Working with Playlists (CN)
Creating and Running a Schedule (CN)
Trigger Events (CN)
RDS Output (CN)
Servo Motors (CN)
Using HLS Sequence Images (12Z)
Importing and Exporting CSV (CN)
Importing a Sequence from Vixen (12Z)
Importing a Sequence from LOR (12Z)
Sharing HLS Sequences (12Z)
Sharing Library Effects (12Z)
Copying and Pasting Channels from Another Sequence (12Z)
Reference Guide
Restoring a Sequence from Backup (12Z)
HLS Dimming Curves (R)
Crosshair Cursor (12Z)
The HLS Toolbar (12Z)
Master Lighting Channel (R)
