Advanced Channel Management
This is based on version 12K.
![](/wiki/images/thumb/8/8d/HLS_ChannelManager_Grid.png/600px-HLS_ChannelManager_Grid.png)
- Channel: This is the numeric value of the channel. These are used when the sequence is sent to controlling hardware. This will remain zero until they are setup in the "output" section.
- Order: This field is used to adjust the order of the channels.
- Display X / Display Y: These numbers are calculated by using the Display Preview and allow the user to plot pixels on an X/Y axis which will allow controlled effects such as color sweeps from left to right or top to bottom. (This is not yet fully implemented.)
Advanced Renaming Channels
![](/wiki/images/thumb/e/ec/HLS_ChannelManager_RenamingSingleChannels_11V.png/300px-HLS_ChannelManager_RenamingSingleChannels_11V.png)
Rename Individual Channels:
![](/wiki/images/thumb/5/5d/HLS_ChannelManager_BulkRename_11V.png/300px-HLS_ChannelManager_BulkRename_11V.png)
Bulk Channel Renaming:
Method One:
- Examples:
Method Two:
Reordering Channels
![](/wiki/images/thumb/4/4a/HLS_ChannelManager_ReorderChannels.png/300px-HLS_ChannelManager_ReorderChannels.png)
To ReOrder channels:
- Click ReOrder Channels.
Using Folders
![](/wiki/images/thumb/7/7b/HLS_FolderName_11V.png/300px-HLS_FolderName_11V.png)
VIDEO: Joe describes folders and folder management
Create a New Folder:
![](/wiki/images/3/33/HLS_ChannelManager_Folder_11V.png)
![](/wiki/images/thumb/3/31/HLS_ChannelManager_FolderPaste1_11V.png/300px-HLS_ChannelManager_FolderPaste1_11V.png)
![](/wiki/images/thumb/a/a8/HLS_ChannelManager_FolderPaste2_11V.png/300px-HLS_ChannelManager_FolderPaste2_11V.png)
To remove channels from a folder:
Opening and Closing Folders:
Folder Tutorial Video: here
Copying Channels
![](/wiki/images/thumb/8/8b/Figure1-20.png/300px-Figure1-20.png)
![](/wiki/images/thumb/c/cd/Figure1-21.png/300px-Figure1-21.png)
To copy multiple channels click on the first channel to be copied and asterisks will appear to the left of the channel name. The without clicking move your mouse down to include all of the channels you would like to copy (see Figure 3-20). Asterisks will appear to the left of the channel to be copied. Once you have selected all of the channels to be copied click again on the last channel to be copied to select all of them.
Deleting Channels
Figure 3-21: Click the Delete Selected Channels button. |
Figure 3-22: Confirm you wish to delete by clicking yes. |
Figure 3-23: HLS will prompt to shut down to update its configuration. Click OK. Then OK again. |
Program Help File
Setting up HLS Channels | Chapter 3: Channel Management | RGB Channels |
