Getting HLS
Download and Installation (12K)
Upgrading HLS (12K)
Creating a Sequence
HLS Sequence Creation Wizard (12K)
Starting a new HLS Sequence (12K)
Time Resolution (12K)
Channel Management
Setting up HLS Channels (12K)
Advanced Channel Management (12K)
RGB Channels (12K)
Configuring Display Groups (12K)
Sticky Channels (12K)
Segment Channels (12K)
Display Preview
Creating a Display Preview (12K)
Creating Basic Effects (12K)
Adding and Using Beat Tracks (12K)
Setting Defaults for Effects (12K)
Creating Chase Effects (12K)
Mirroring Effects (12K)
Fill Effects (12K)
Submaster Lighting Channels (12K)
Sequencing with RGB Channels (In Process)
Custom Effects (R)
Creating a PixelPlane (12P)
The PixelPlane Editor (12P)
The PixelPlane Editor: Vertical Matrix (Under Development)
The PixelPlane Editor: Creating Effects (12P)
Using Nutcracker with a PixelPlane
Fill Channels (12K)
PixelPlane Transitions Using Lighting Channels (12K)
Drawing a PixelPlane in the Display Preview (12K)
Sequence Playback
Sequence Playback (12K)
Sequence Output
Hardware Configuration (R)
Selecting the Output Method
Working with Playlists
Trigger Events
RDS Output
Servo Motors
Importing a Sequence from Vixen (12E)
Importing a Sequence from LOR (12E)
Moving or Sharing Sequences
Sharing Library Effects
Reference Guide
Restoring a Sequence from Backup (12E)
HLS Dimming Curves (R)
Crosshair Cursor (12E)
Master Lighting Channel
