Creating a PixelPlane
Current as of Version 12K.
What is a PixelPlane?
VIDEO: Joe describes a PixelPlane and creating a PixelPlane in his HLS 2013 Intro video
How to Create a PixelPlane
- Assign the type of PixelPlane that you have and then click "Assign Type of PixelPlane."
 - Note:As of version 12H, only type "Mega Tree" is currently supported.
 - Complete the fields to help HLS understand your PixelPlane object, then click OK (See Figure 6-4).
| Chapter 5: Sequencing Channels and Adding Effect | Chapter 6: The PixelPlane | The PixelPlane Editor |
