Creating Basic Effects
Pictures will be added soon.
Based on Version 11V.
The HLS Sequencing Window has four basic components which are important when sequencing (See Figure 5-1).
 - The Undo Last Effect button removes the last effect applied.
Selection Mode in HLS
Basic Method to Create a Selection Box:
 - All of the cells you have chosen will be surrounded by a dotted line. (See Figure 4-X).
Basic Effects
Level:
- Shortcut key: L
Ramp Up:
- Shortcut key: U
Ramp Down:
- Shortcut key: D
Modifying Effects
Moving Effects:
Deleting Single Effects:
Deleting an Area of Effects:
Copy/Paste Effects:
 - Select the effect you wish to copy by CTRL Left-Clicking the left-most cell to copy. (This lets HLS know that you are wanting to select cells rather than move the effect.)
Modify Effect Attributes:
 - Right-click an effect and select Modify Effect. The Modify Effect window will appear (See Figure 5-X).
