Creating Basic Effects
Pictures will be added soon.
Based on Version 11V.
Complete this section.
The Window and it's components
The Toolbar and relevant buttons
The Sequencer Window:
The HLS Sequencing Window has four basic components which are important when sequencing (See Figure 5-1).
- The first component, highlighted in blue, is the toolbar for applying effects in a sequence.
 - The Undo Last Effect button removes the last effect applied.
 - The second component, highlighted in yellow, is the audio oscilloscope and the time bar, which shows where you are in the song.
 - The third component, highlighted in turquoise, is the listing of channels that are currently being viewed.
 - The fourth component, highlighted in purple, is the sequence grid, which contains the cells where effects are applied to channels.
Selection Mode in HLS
Basic Method to Create a Selection Box:
 - All of the cells you have chosen will be surrounded by a dotted line. (See Figure 4-X).
Basic Effects
Level:
- Shortcut key: L
Ramp Up:
- Shortcut key: U
Ramp Down:
- Shortcut key: D
Modifying Effects
Moving Effects:
Deleting Single Effects:
Deleting an Area of Effects:
Copy/Paste Effects:
 - Select the effect you wish to copy by CTRL Left-Clicking the left-most cell to copy. (This lets HLS know that you are wanting to select cells rather than move the effect.)
Modify Effect Attributes:
 - Right-click an effect and select Modify Effect. The Modify Effect window will appear (See Figure 5-X).
