Creating Basic Effects
Under Development.
Based on Version 11V.
The Window and it's components
The Toolbar and relevant buttons
The Edit Mode in HLS
Applying effects to channels in HLS works differently than some other sequencing programs. When you click the left mouse button in the channel grid, the Edit Mode becomes active and will remain active until you click again or press the ESC key.
- TIP: Sometimes it may appear as if HLS is unresponsive or hung up. Most likely, you are in Edit Mode and it is waiting for that operation to complete. If things ever appear hung up or you have made a selection you do not want, press ESC.
Basic Method to Apply an Effect:
 - All of the cells you have chosen will be surrounded by a dotted line. (See Figure 4-X).
Basic Effects
Level
Ramp Up
Ramp Down
Modifying Effects
Moving/Stretching Effects
Deleting Effects
Copy/Paste Effects
Modify Effect Attributes
