Getting HLS
Upgrading HLS (11V)
Creating a Sequence
Audio File (11V)
Time Resolution (11V)
Channel Management
Setting up HLS Channels (11V)
Advanced Channel Management (11V)
RGB Channels (11V)
Configuring Display Groups (11V)
Sticky Channels (R)
Display Preview
Adding and Using Beat Tracks (R)
Creating Basic Effects
Setting Defaults for Effects (R)
Creating Chase Effects (R)
Mirroring Effects (R)
Fill Effects
Over Control Effects (R)
Sequencing with RGB Channels
Custom Effects (R)
The PixelPlane
PixelPlane Editor
MegaTree
Sequence Playback
Sequence Playback (R)
Sequence Output
Hardware Configuration (R)
Selecting the Output Method
Working with Playlists
Trigger Events
RDS Output
Servo Motors
Importing a Sequence from Vixen (R)
Moving or Sharing Sequences
Sharing Library Effects
Reference Guide
HLS Dimming Curves (R)
Crosshair Cursor (11V)
