Advanced Channel Management
This is based on version 11V.
- Channel: This is the numeric value of the channel. These are used when the sequence is sent to controlling hardware.
- Order: This field is used to adjust the order of the channels.
- Multiple DMX Group: A normal DMX universe has 512 channels. This is active when using hardware that allows 4096 channels per universe.
Advanced Renaming Channels
Rename Individual Channels:
- When done, Click Save All Channels.
Bulk Channel Renaming:
Method One:
- Examples:
Method Two:
Reordering and Renumbering Channels
To ReOrder channels:
- Once the channels have been ReOrdered, click Renumber All Channels for Output to update the Order column (and the Channel column if Universe is greater than zero).
- Click ReOrder Channels.
- Click Renumber all Channels for Output.
Using Folders
Create a New Folder:
To remove channels from a folder:
Opening and Closing Folders:
Folder Tutorial Video: here
Copying Channels
To copy one or more channels click on the channel and asterisks will appear to the left of the channel name (see Figure 1-20). The click again on the channel to select it. Then Select the Manage Channels tab and choose Copy - Paste Whole Channels. You will then be prompted to Click on the Channel to Paste To.
To copy multiple channels click on the first channel to be copied and asterisks will appear to the left of the channel name. The without clicking move your mouse down to include all of the channels you would like to copy (see Figure 1-21). Asterisks will appear to the left of the channel to be copied. Once you have selected all of the channels to be copied click again on the last channel to be copied to select all of them.
Deleting Channels
| Figure 3-17: Click the Delete Selected Channels button. |
| Figure 3-18: Confirm you wish to delete by clicking yes. |
| Figure 3-19: HLS will prompt to shut down to update its configuration. Click OK. Then OK again. |
Program Help File
| Setting up HLS Channels | Chapter 3: Channel Management | RGB Channels |
