Revision as of 21:46, 29 January 2013 by Jklingert (talk | contribs) (ACL)
PIXEL CONTROLLERS
SanDevices
E68x Configuration Guide
Firmware Updates
Model Max Pixels DMX Universes Pixels Supported Output Connectors Max Channels DMX Universes per Output Image Link Price Manual Note
PS-1 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link Turnkey System: $399 Owner's Assembled E682 with power supply in an Enclosure
E682-12 2040 6Multicast / 12Unicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 6120 Up to 12 link Assembled/Tested: $180, Full Kit: Price $109 Owner's Assembly To be released shortly
E682-6 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link Assembled/Tested: $180, Full Kit: Price $109 Owner's Assembly Original E682, Before Firmware Upgrade
E681-12 2040 6Multicast / 12Unicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 6120 Up to 12 link No Longer Available Owner's Assembly Firmware To be released shortly, requires UP1 upgrade
E681-6 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link No Longer Available Owner's Assembly Original E681, with Firmware Upgrade and UP1 upgrade
E681-4 680 4Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 2040 Up to 4 link No Longer Available Owner's Assembly Original E681, without Firmware Upgrade and without UP1 upgrade
E680-12 2040 6Multicast / 12Unicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 6120 Up to 12 link Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function Owner's Assembly To be released shortly, requires UP1 upgrade
E680-6 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function Owner's Assembly Original E680, with Firmware Upgrade and UP1 upgrade
E680-4 680 4Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 2040 Up to 4 link Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function Owner's Assembly Original E680, without Firmware Upgrade and without UP1 upgrade
Joshua 1 Systems (J1SYS)
Tutorial Video
Setup Video
ECG-P12R 2040 12Unicast LPD6803, WS2801, WS2811, TM180x, TLS3001 12 Fused (2x6 Electrical, 3x4 Logical) 6120 1 link Assembled Board: $175 Owner's Notes
ECG-PIXAD8 1360 8Unicast LPD6803, WS2801, WS2811, TM180x, TLS3001 8 Fused (2x4 Electrical, 2x4 Logical) 4080 1 link Assembled Board: $155 Owner's
ECG-P2 1360 8Unicast LPD6803, WS2801, WS2811, TM180x, TLS3001 2 Unfused (2x1 Electrical, 2x1 Logical) 4080 4 link Assembled Board: $68, Assembled Board w/case: $77 Owner's
Stellascapes
E16-II Green 672 6Unicast Stella-green 16 Fused (? Electrical, ? Logical) 2016 ? link Assembled Board: $1296 16 Character LCD Display for diagnostics and identification information.
E16-II Commercial 672 6Unicast Stella-black 16 Fused (? Electrical, ? Logical) 2016 ? link Assembled Board: $1995 With power supply and 16 400mm "tails" with waterproof screw up connectors
E16-II Pro 672 6Unicast Stella-black 16 Fused (? Electrical, ? Logical) 2016 ? link Assembled Board: $?? With power supply and Neutrik XLR, power and ethernet chasis connectors
E2 170 1Unicast Stella-black 2 ? 512 ? link Assembled Board: $?? With power supply,operates on low voltage DC (12-48V)
DMX512 to SPI
DCG-P2 170/680* 1DMX/*4HyperDMX LPD6803, WS2801, WS2811, TM180x, TLS3001 2 Unfused (1x2 Electrical, 1x2 Logical) 512DMX/*2048HyperDMX 1 link Assembled Board: $53 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels
uDCG-P2 170/680* 1DMX/*4HyperDMX LPD6803, WS2801, WS2811, TM180x, TLS3001 2 Unfused (1x2 Electrical, 1x2 Logical) 512DMX/*2048HyperDMX 1 link Assembled Board: $42, Assembled Board w/Case: $48 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels
Ray Wu
(China Based)
AVD
ACL Wiki
ACL Thread
ACL
Onumen
RPM
Stellascapes
  • T3: DMX512 - SPI Bridge
SD Memory Card to SPI
Ray Wu
(China Based)
PIXEL Extenders
ECG-PPX
E1.31 Bridges and DMX Dongles
DIYLEDEXPRESS
RPM
Discussion Thread
USB to DMX512
FTDI drivers for dongles:
RGB Controllers Feature Comparisons
DC Controller Comparison Table
Audiolight Intl HD-714 [1] [2] Yes 12V - 24V 3 2A 6A DMX $8.95 $2.98
Audiolight Intl HD-712 [3] [4] Yes 12V - 24V 27 1A 15A DMX $44.21 $1.64
Leynew LN-DMXMODEL-3CH-LV12 [5] [6] Yes 12V 3 2A 6A DMX $7.49 $2.49
