Revision as of 20:31, 29 January 2013 by Jklingert (talk | contribs) (Ray Wu)
PIXEL CONTROLLERS
SanDevices
E68x Configuration Guide
Firmware Updates
Model Max Pixels DMX Universes Pixels Supported Output Connectors Max Channels DMX Universes per Output Image Link Price Manual Note
PS-1 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link Turnkey System: $399 Owner's Assembled E682 with power supply in an Enclosure
E682-12 2040 6Multicast / 12Unicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 6120 Up to 12 link Assembled/Tested: $180, Full Kit: Price $109 Owner's Assembly To be released shortly
E682-6 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link Assembled/Tested: $180, Full Kit: Price $109 Owner's Assembly Original E682, Before Firmware Upgrade
E681-12 2040 6Multicast / 12Unicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 6120 Up to 12 link No Longer Available Owner's Assembly Firmware To be released shortly, requires UP1 upgrade
E681-6 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link No Longer Available Owner's Assembly Original E681, with Firmware Upgrade and UP1 upgrade
E681-4 680 4Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 2040 Up to 4 link No Longer Available Owner's Assembly Original E681, without Firmware Upgrade and without UP1 upgrade
E680-12 2040 6Multicast / 12Unicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 6120 Up to 12 link Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function Owner's Assembly To be released shortly, requires UP1 upgrade
E680-6 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function Owner's Assembly Original E680, with Firmware Upgrade and UP1 upgrade
E680-4 680 4Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 2040 Up to 4 link Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function Owner's Assembly Original E680, without Firmware Upgrade and without UP1 upgrade
Joshua 1 Systems (J1SYS)
Tutorial Video
Setup Video
ECG-P12R 2040 12Unicast LPD6803, WS2801, WS2811, TM180x, TLS3001 12 Fused (2x6 Electrical, 3x4 Logical) 6120 1 link Assembled Board: $175 Owner's Notes
ECG-PIXAD8 1360 8Unicast LPD6803, WS2801, WS2811, TM180x, TLS3001 8 Fused (2x4 Electrical, 2x4 Logical) 4080 1 link Assembled Board: $155 Owner's
ECG-P2 1360 8Unicast LPD6803, WS2801, WS2811, TM180x, TLS3001 2 Unfused (2x1 Electrical, 2x1 Logical) 4080 4 link Assembled Board: $68, Assembled Board w/case: $77 Owner's
Stellascapes
E16-II Green 672 6Unicast Stella-green 16 Fused (? Electrical, ? Logical) 2016 ? link Assembled Board: $1296 16 Character LCD Display for diagnostics and identification information.
E16-II Commercial 672 6Unicast Stella-black 16 Fused (? Electrical, ? Logical) 2016 ? link Assembled Board: $1995 With power supply and 16 400mm "tails" with waterproof screw up connectors
E16-II Pro 672 6Unicast Stella-black 16 Fused (? Electrical, ? Logical) 2016 ? link Assembled Board: $?? With power supply and Neutrik XLR, power and ethernet chasis connectors
DMX512 to SPI
DCG-P2 170/680* 1DMX/*4HyperDMX LPD6803, WS2801, WS2811, TM180x, TLS3001 2 Unfused (1x2 Electrical, 1x2 Logical) 512DMX/*2048HyperDMX 1 link Assembled Board: $53 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels
uDCG-P2 170/680* 1DMX/*4HyperDMX LPD6803, WS2801, WS2811, TM180x, TLS3001 2 Unfused (1x2 Electrical, 1x2 Logical) 512DMX/*2048HyperDMX 1 link Assembled Board: $42, Assembled Board w/Case: $48 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels
AVD
ACL Wiki
ACL Thread
ACL
Onumen
RPM
Ray Wu
(China Based)
Stellascapes
  • T3: DMX512 - SPI Bridge
  • E2: Ethernet - SPI Bridge
PIXEL Extenders
ECG-PPX
E1.31 Bridges and DMX Dongles
DIYLEDEXPRESS
6Port E1.31 Bridge
RPM
E1.31 to DMX Bridge
Discussion Thread
USB to DMX512
FTDI drivers for dongles:
RGB Controllers Feature Comparisons
DC Controller Comparison Table
Audiolight Intl HD-714 [1] [2] Yes 12V - 24V 3 2A 6A DMX $8.95 $2.98
Audiolight Intl HD-712 [3] [4] Yes 12V - 24V 27 1A 15A DMX $44.21 $1.64
Leynew LN-DMXMODEL-3CH-LV12 [5] [6] Yes 12V 3 2A 6A DMX $7.49 $2.49
