PIXEL CONTROLLERS
SanDevices
Joshua 1 Systems (J1SYS)
Stellascapes
| E16-II Pro | 672 | 6Unicast | Stella-black | 16 Fused (? Electrical, ? Logical) | 2016 | ? | link | Assembled Board: $?? | With power supply and Neutrik XLR, power and ethernet chasis connectors |
DMX512 to SPI
| DCG-P2 | 170/680* | 1DMX/*4HyperDMX | LPD6803, WS2801, WS2811, TM180x, TLS3001 | 2 Unfused (1x2 Electrical, 1x2 Logical) | 512DMX/*2048HyperDMX | 1 | link | Assembled Board: $53 | 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels | ||
| uDCG-P2 | 170/680* | 1DMX/*4HyperDMX | LPD6803, WS2801, WS2811, TM180x, TLS3001 | 2 Unfused (1x2 Electrical, 1x2 Logical) | 512DMX/*2048HyperDMX | 1 | link | Assembled Board: $42, Assembled Board w/Case: $48 | 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels |
AVD
ACL
Onumen
RPM
Ray Wu
- Mini protocol Decoder;DMX to WS2801,512 dmx address decoded
 - DD-100 series mini DMX protocol decoder;support WS2801 protocol control signal
 - LT-DMX-1809(WS2811) DMX Decoder;support WS2811,TM1804,TM1809,TM1812 driving IC;DC5V-24V input
 - LT-DMX-2801 DMX-SPI Decoder;support WS2801,WS2803 drving IC
 - LT-DMX-3001 DMX-SPI Decoder;support TLS3001, TLS3002 driving IC
 - LT-DMX-9813 DMX-SPI Decoder;support P9813 drving IC
 - DD-1000 series DMX protocol decoder;support WS2801 IC;can decodering 512 address
 - DD-1000 series DMX protocol decoder;support LPD6803IC signal;can decodering 512 address
Stellascapes
- T3: DMX512 - SPI Bridge
- E2: Ethernet - SPI Bridge
PIXEL Extenders
ECG-PPX
E1.31 Bridges and DMX Dongles
DIYLEDEXPRESS
RPM
USB to DMX512
 - Enttec Open DMX USB
 - Enttec DMX USB Pro
 - RPM DIY USB to DMX Adaptor
FTDI drivers for dongles:
RGB Controllers Feature Comparisons
| Audiolight Intl | HD-714 [1] [2] | Yes | 12V - 24V | 3 | 2A | 6A | DMX | $8.95 | $2.98 |
| Audiolight Intl | HD-712 [3] [4] | Yes | 12V - 24V | 27 | 1A | 15A | DMX | $44.21 | $1.64 |
| Leynew | LN-DMXMODEL-3CH-LV12 [5] [6] | Yes | 12V | 3 | 2A | 6A | DMX | $7.49 | $2.49 |
