Different Styles of Pixels
Revision as of 22:49, 26 January 2013 by Jklingert (talk | contribs) (Ray Wu: added pricing as of 1-26-13)
Pixel Properties
Form Factor
  • Strings (Can be any length, but more then 50 pixels will require power injection)
    1. 12mm pixel
    2. 12mm pixel (square)
  • Strips (Usually 5M length)
    1. Bare board (no waterproofing)
    2. Hollow Tube
    3. Coated Strips
      • Silicone Coating
      • Epoxy Resin Coating
    4. Solid Tube
      • Solid Silicone
      • Solid Epoxy Resin
  • Modules
    1. Square
    2. Rectangular
LEDs per meter
  • Strips
    1. 30 LED/m
    2. 60 LED/m
  • Strings
    1. 10 LED/m (100mm spacing between nodes is common )
Power Supply Voltage
    1. 5VDC
    2. 12VDC
    3. 24VDC
LED Type
    1. 3528 surface mount (3.5mm x 2.8mm) (typically used in strips and modules)
    2. 5050 surface mount (5.0mm x 5.0mm) (typically used in strips and modules)
    3. 8mm (typically used in strings)
Waterproofing
    1. Injection Molded Silicone
    2. Cast Epoxy Resin in Sleeve
    3. Cast Epoxy Resin coated PCB
    4. Silicone Tube
      1. Hollow Tube
      2. Silicone Filled Tube
    5. Silicone Coated Strip
    6. Epoxy Coated Strip
Wire Size
    1. 18 Gauge wire (Thicker, better for longer distance or more pixels)
    2. 20 Guage wire
      • LPD8806
      • LPD8809
      • MY9941 (Native DMX)
      • MY9942 (Native DMX)
      • MY9943 (Native DMX)
DIYLEDEXPRESS
String WS2801 50 pixels (6m) 5vdc 10 10 link $26.00 $0.52 IP68
String WS2811 50 pixels (6m) 5vdc 10 10 link $24.25 $0.49 IP68
String (Square) WS2811 50 pixels (6m) 12vdc 10 10 link $25.75 $0.52 IP68, back wire
Module (Rectangular) WS2811 20 pixels (2m) 12vdc 10 10 link $16.75 $0.84 3 LEDs
Light-O-Rama (LOR)
(USA Based)
String LPD6803 100 pixels (15.25m) TBDvdc 6.5 6.5 link $239.95 $2.40 Cosmic Color Pixels (with controller and Power Supply)
Bulbs LPD6803 100 pixels (15.25m) TBDvdc 6.5 6.5 link $289.95 $2.90 Cosmic Color Bulbs (with controller and Power Supply)
Strip LPD6803 50 pixels (5m) TBDvdc 30 10 link $249.95 $2.50 Cosmic Color Ribbon (with controller and Power Supply)
Ray Wu
(China Based)
Retail Store (i.e. Lowes)
String GECE 25,36,50 pixels (20,29,41ft) 5vdc 4 4 link G35 Cover, General Electric Color Effects
Seasonal Entertainment
String WS2801 42 pixels (4.2m) 12vdc 10 10 link $32.00 $0.76 IP68, Rainbow Mini Pixels
String (square) WS2801 42 pixels (8.4m) 12vdc 5 5 link $43.00 $1.02 IP68, Rainbow C7 Pixels
String (square) WS2801 42 pixels (8.4m) 12vdc 5 5 link $45.00 $1.07 IP68, Rainbow C9 Pixels
Strip WS2801 42 pixels (4.2m) 12vdc 30 10 link $73.99 $1.76 IP68, Silicone filled, Rainbow Ribbon
Matrix WS2801 42 pixels (0.15x0.18m) 12vdc xx xx link $35.00 $0.83 Not Waterproof, Rainbow Matrix
Stellascapes
String (Stella-green) SS-1 85 pixels 5vdc 10 10 link $168 $1.98 bullet or flat packages
String (Stella-black) SS-1 85 pixels 5vdc 10 10 link $240 $2.82 bullet or flat packages
DIYLEDEXPRESS
HolidayCoro
String None 50 nodes (5m) 12vdc 10 0 link $32.50 $0.65
Strip None 5m 12vdc 30 0 link $49.99 $10.00/m silicone tube and coating
Module (rectangular) None 20 nodes 12vdc 10 0 link $25.80 $1.29 3 LEDs
Module (square) None 20 nodes 12vdc 10 0 link $27.80 $1.39 3 LEDs
Ray Wu
(China Based)
String None 50 nodes (5m) 12vdc 10 0 link $19.00 $0.38 IP68
String (square) None 50 nodes (10m) 12vdc 5 0 link $38.99 $0.78 IP68, RGB C7 lens
String (square) None 50 nodes (10m) 12vdc 5 0 link $39.99 $0.80 IP68, RGB C9 lens
Strip None 5m 12vdc 30 0 link $38.50 $7.70/m IP68, Silicone filled
