Different Styles of Pixels
Revision as of 20:16, 26 January 2013 by Jklingert (talk | contribs) (Ray Wu: addedWS2812 WS2811 with integrated 5050 LED)
Pixel Properties
Form Factor
  • Strings (Can be any length, but more then 50 pixels will require power injection)
    1. 12mm pixel
    2. 12mm pixel (square)
  • Strips (Usually 5M length)
    1. Bare board (no waterproofing)
    2. Hollow Tube
    3. Coated Strips
      • Silicone Coating
      • Epoxy Resin Coating
    4. Solid Tube
      • Solid Silicone
      • Solid Epoxy Resin
  • Modules
    1. Square
    2. Rectangular
LEDs per meter
  • Strips
    1. 30 LED/m
    2. 60 LED/m
  • Strings
    1. 10 LED/m (100mm spacing between nodes is common )
Power Supply Voltage
    1. 5VDC
    2. 12VDC
    3. 24VDC
LED Type
    1. 3528 surface mount (3.5mm x 2.8mm) (typically used in strips and modules)
    2. 5050 surface mount (5.0mm x 5.0mm) (typically used in strips and modules)
    3. 8mm (typically used in strings)
Waterproofing
    1. Injection Molded Silicone
    2. Cast Epoxy Resin in Sleeve
    3. Cast Epoxy Resin coated PCB
    4. Silicone Tube
      1. Hollow Tube
      2. Silicone Filled Tube
    5. Silicone Coated Strip
    6. Epoxy Coated Strip
Wire Size
    1. 18 Gauge wire (Thicker, better for longer distance or more pixels)
    2. 20 Guage wire
      • LPD8806
      • LPD8809
      • MY9941 (Native DMX)
      • MY9942 (Native DMX)
      • MY9943 (Native DMX)
DIYLEDEXPRESS
Form Factor IC Length Voltage LEDs per Meter ICs per meter Link Image Note
String WS2801 50 pixels (6m) 5vdc 10 10 link IP68
String WS2811 50 pixels (6m) 5vdc 10 10 link IP68
String (Square) WS2811 50 pixels (6m) 12vdc 10 10 link IP68, back wire
Module (Rectangular) WS2811 20 pixels (2m) 12vdc 10 10 link 3 LEDs
Strip WS2811 50 pixels (5m) 5vdc 30 10 link silicone tube
Strip WS2811 100 pixels (5m) 5vdc 60 20 link silicone tube
Strip TM1809 150 Pixels (5m) 12vdc 30 10 link silicone tube
Light-O-Rama (LOR)
(USA Based)
String LPD6803 100 pixels (15.25m) TBDvdc 6.5 6.5 link Cosmic Color Pixels (with controller and Power Supply)
Bulbs LPD6803 100 pixels (15.25m) TBDvdc 6.5 6.5 link Cosmic Color Bulbs (with controller and Power Supply)
Strip LPD6803 50 pixels (5m) TBDvdc 30 10 link Cosmic Color Ribbon (with controller and Power Supply)
Ray Wu
(China Based)
String WS2801 50 pixels (5m) 5vdc 10 10 link IP68
String WS2801 50 pixels (5m) 5vdc 10 10 link IP68, with faceted C9 cover
String WS2801 100 pixels (10m) 12vdc 10 10 link IP68
String (square) WS2801 50 pixels (5m) 5vdc 10 10 link IP68, back wire
String (square) WS2801 50 pixels (5m) 5vdc 10 10 link IP66, side wire
String (square) WS2801 50 pixels (5m) 5vdc 10 10 link IP68, with faceted C9 cover
Strip WS2801 160 pixels (5m) 5vdc 32 32 link IP65, silicone tube
Strip WS2801 60 pixels (5m) 12vdc 36 12 link IP65, silicone tube
Module (square) WS2801 20 pixels 12vdc 40 10 link
String WS2811 50 pixels (5m) 5vdc 10 10 link IP68
String WS2811 50 pixels (5m) 5vdc 10 10 link IP66, with 4 pin waterproof connectors
String (square) WS2811 50 pixels (5m) 5vdc 10 10 link IP68, back wire
String (square) WS2811 100 pixels (10m) 12vdc 10 10 link IP66, side wire
Strip WS2811 150 pixels (5m) 5vdc 30 30 link silicone tube
Module (rectangular) WS2811 20 pixels 12vdc 30 10 link
Strip WS2812 240 pixels (4m) 5vdc 60 60 link silicone tube, WS2811 with integrated 5050 LED
String LPD6803 50 Pixels (5m) 5vdc 10 10 link IP68
String (square) LPD6803 50 Pixels (5m) 5vdc 10 10 link IP68, side wire
Strip LPD6803 50 Pixels (5m) 12vdc 30 10 link IP68, similar to LOR CCR
Module (square) LPD6803 20 pixels (2m) 12vdc 10 10 link 3 LEDs
Module (rectangular) LPD6803 20 pixels (2m) 12vdc 10 10 link 3 LEDs
String TLS3001 50 pixels (5m) 5vdc 10 10 link IP68
String TLS3001 50 pixels (5m) 5vdc 10 10 link IP68, with 4 pin waterproof connectors
String (square) TLS3001 50 pixels (5m) 5vdc 10 10 link IP68, back wire
Strip TM1809 150 pixels (5m) 12vdc 30 10 link IP67, silicone tube
Strip TM1809 150 pixels (5m) 12vdc 30 10 link IP65, silicone coating
Strip TM1809 240 pixels (5m) 12vdc 48 16 link IP68, silicone tube
Retail Store (i.e. Lowes)
String GECE 25,36,50 pixels (20,29,41ft) 5vdc 4 4 link G35 Cover, General Electric Color Effects
Seasonal Entertainment
String WS2801 42 pixels (4.2m) 12vdc 10 10 link IP68, Rainbow Mini Pixels
String (square) WS2801 42 pixels (8.4m) 12vdc 5 5 link IP68, Rainbow C7 Pixels
String (square) WS2801 42 pixels (8.4m) 12vdc 5 5 link IP68, Rainbow C9 Pixels
Strip WS2801 42 pixels (4.2m) 12vdc 30 10 link IP68, Silicone filled, Rainbow Ribbon
Matrix WS2801 42 pixels (0.15x0.18m) 12vdc xx xx link Not Waterproof, Rainbow Matrix
Stellascapes
String (Stella-green) SS-1 85 pixels 5vdc 10 10 link bullet or flat packages
String (Stella-black) SS-1 85 pixels 5vdc 10 10 link bullet or flat packages
DIYLEDEXPRESS
String None 50 nodes (5m) 5vdc 10 0 link IP68
String None 50 nodes (5m) 12vdc 10 0 link IP68
Strip None 5m 12vdc 30 0 link IP65, can be cut every 3 LEDs
Strip None 5m 12vdc 60 0 link IP65, can be cut every 3 LEDs
Module (rectangular) None 20 nodes 12vdc 30 0 link IP66
HolidayCoro
Strip None 5m 12vdc 30 0 link silicone tube and coating
Module (rectangular) None 20 nodes 12vdc 10 0 link 3 LEDs
Module (square) None 20 nodes 12vdc 10 0 link 3 LEDs
Ray Wu
(China Based)
String None 100 nodes (10m) 12vdc 10 0 link IP68
Strip None 5m 12vdc 30 0 link IP68,silicone coating
Strip None 5m 12vdc 30 0 link IP68,silicone tube and coating
Strip None 5m 12vdc 30 0 link epoxy coating
Strip None 5m 12vdc 60 0 link silicone tube
Strip None 5m 12vdc 60 0 link IP68,silicone tube and coating
Strip None 5m 12vdc 60 0 link epoxy coating
Module (rectangular) None 20 nodes 12vdc 10 0 link IP65, 2 LEDs
Module (rectangular) None 20 nodes 12vdc 10 0 link IP66, 3 LEDs
Module (square) None 20 nodes 12vdc 10 0 link IP68, 3 LEDs
Module (square) None 20 nodes 12vdc 10 0 link IP67, 4 LEDs
