Ohm's Law
Ohm's Law
Ohm's Law is a formula that relates the basic electrical properties of Voltage, Current and Resistance. These properties can be measured with a multimeter.![]()
- V=IR
- V=IR
Ohm's Law Diagram
Voltage (V)
AC Voltage
- AC Alternating Current
- Common values:
- Common values:
DC Voltage
- DC Direct Current
- Common values:
- Many integrated circuits require 5 volts DC (VDC) to power them.
- Common values:
Voltage Formulas
- V=IR
- V=√PR
- V=P/I
Voltage Examples
- What is the voltage drop across a 4 Ω resistor that has a current of 0.3A?
V=IR, V=(0.3)(4)=1.2V - What is the voltage across a 5W lamp with a resistance of 2 Ω?
V=√PR=√(5)(2)=√10=3.16V - What is the voltage across a 1 W LED that has a current of 0.35A running thru it?
V=P/I, V=1/0.35= 2.86V
Current (I)
- Common values:
- A typical string of 100 count incandescent lights draws 0.33A.
Current Formulas
- I=V/R
- I=P/V
- I=√P/R
Current Examples
- How much current flows thru a 680 Ω resistor that has 5V applied to it?
I=V/R, I=5/680=0.007A (7 ma) - How much current is used by a 75W floodlight using 120V?
I=P/V, I=75/120=0.625A - What is the current thru a 5W lamp with a resistance of 2 Ω?
V=√P/R=√(5)/2=2.24/2=1.12A
Resistance (R)
- Common values:
Resistance Formulas
- R=V/I
- R=V²/P
- R=P/I²
Resistance Examples
- What value resistor do you need to drop 3V and allow 20ma thru the circuit?
R=V/I=3/0.020=150Ω - What is the resistance of a 120V light string that draws 40W?
R=V²/P=(120)²/40=14400/40=360Ω - What is the resistance of a 1W LED that draws 350ma?
R=P/I²=1/(0.35)²=1/0.123)=8.16Ω
Power (P)
- P=VI
- Power=Voltage x Current
- P=VI
- Common values:
Power Formulas
- P=VI
- P=I²R
- P=V²/R
Power Examples
- How much power does a 100 count string of 120V incandescent lights that use 0.33A use?
P=VI=(120)(0.33)=39.6 W - How much power does a 4 Ω resistor dissipate as heat that has 0.3A running thru it?
P=I²R=(0.35)²(4)= (0.123)(4)=0.49 W - How much power does a 10 Ω resistor dissapate as heat that has 12V across it?
P=V²/R=(12)²/10=144/10=14.4W
LED Calculator
By using Ohm's Law you can calculate the current limiting resistor needed to include in a circuit with a LED.
Single LED
LED Calculator for 1 LED.
Array of LEDs
LED Calculator for an array of LEDs.
Pixel Voltage Drop Calculator
Thread
