Ohm's Law
Ohm's Law
- V=IR
- V=IR
Ohm's Law Diagram
Voltage (V)
- AC Alternating Current
- Example:
- Example:
- DC Direct Current
- Example:
- Many Integrated Circuits require 5 volts DC (VDC) to power them.
- Example:
Formulas
<math>\sqrt{\pi}</math>
Current (I)
- Example:
- A typical string of 100 count incandescent lights draws 0.33A.
Resistance (R)
- Example:
Power (P)
- P=VI
- Power=Voltage x Current
- P=VI
- Example:
LED Calculator
Use these calculators to calculate the resistor needed to include in a circuit with a LED.
Single LED
LED Calculator for 1 LED.
Array of LEDs
LED Calculator for an array of LEDs.
