What is the TIR Flood?
These are commercial RGB outdoor DMX floodlights designed and sold by TIR.  They are Model Number: Destiny CG-WGO-RGB-CUS-V2  These lights were originally mounted on the Duke Energy Building and were replaced with other RGB fixtures.  rfallatt arranged to buy the lights from the building and offered them to users via a group buy in August 2012.  There was a mixture of working and bad units sold.  The bad units suffered from water entering either the control module or the power supply.  TIR Systems (in Canada) were considered the leader in outdoor LED systems and were also popular with large dance halls. They were a public stock company until 2007 when Phillips purchased them.
Manufacturer's Description
How does the TIR Flood work?
These are RGB flood lights that are controlled via DMX and possibly via an unidentified ethernet based protocol.  There is a 5 pin XLR DMX connector that comes configured for DMX input only.  Out of the box these units respond to DMX channels 1-3 when powered up and connected to a signal source.  These units will fall back to a test sequence if the DMX signal is not applied.  The test sequence is a series of color fades.  The units also come with a ethernet cable attached and the control protocol has not been established for using it.
Dimensions of the TIR Flood
TIR Flood Components
Connectors
The units come equipped with a 15A 125vAC 3 Pin Twistlock power plug, a RJ45 ethernet interface cable and a 5 PIN XLR DMX cable attached.  The power and DMX cable come out of the base of the mounting bracket thru the waterproof cable holders.  The ethernet cable is tucked inside the base of the mounting bracket and has a rubber waterproof sleeve on the end.
Housing
The main housing has the sealed LED Assembly attached to the front and has an internal compartment open to the environment that houses the waterproof control unit and the waterproof power supply.
LED Assembly
The flood lights have 48 Luxeon LEDs mounted in a sealed module on the front of the unit.  There are 16 each of Red, Blue and Green.  The LEDs are mounted on two PCB boards. The LEDs are arranged in a 2x6 array for each color on the upper PCB and 1x4 on the lower PCB.  This video shows how to test the LED Assembly when removed from the housing.
Control Module
There is a control module that drives the LEDs and responds to the DMX commands provided to it thru the DMX interface. The Control Module is mounted inside a waterproof housing and is attached to the rear heatsink with a generous amount of heatsink compound.  Inside of the Control Module there are some HEXFETs that appear to be driving the LEDs (IRL510S). There's a LM2676 5V regulator nearby some of these.
Ethernet Module
There is an  ethernet module mounted inside the control module.  The interface to this module has not been identified yet. Technical Information about the Netburner ethernet module.  The NetBurner module uses the ColdFire MCF5282 processor.  Using the Netburner IP program, one user got the following response "MOD5282 Unit: at 192.168.1.47 running :LuminaireFX (3081041) $Date: 2005/02/04 18:42:48 $, $Name: B_Dma6Aug2004_MainTest $".
Power Supply
The power supply is a 100-240 VAC input and 24.5VDC 3.3A output.  They are sealed in a waterproof enclosure and the wires come through the enclosure via waterproof sealing glands.
The power supply has an input power cord on one end and has a red and black wire on the other end that connects to the control housing.
Mounting Bracket
Disassembling the TIR Flood
Main Body Separation
- Remove the 3 screws near the rounded back edge on both side panels near the bracket attachment.
TIR Flood Power Requirements
The units come equipped with a 15A 125vAC 3 Pin Twistlock power plug.  At 100% brightness RGB the flood draws 78 watts @116.5vAC.  The internal power supply provides 24vdc @ 3.3A to the control electronics.  A quick test of the current of the Red LEDs shows to be about 760-780 mA when full on.
Controlling the TIR Flood
The flood comes equipped with a 5 pin XLR DMX connector. Only the  input wires are connected to the XLR connector, but the output wires are also available and they can be soldered to the plug.  It is believed that these floods were controlled by a software package called LuminaireFX.  This is the Control software developed by TIR for this unit. It's a control system for their "TBus" option.
Wiring Color Codes
| LED Connection | Wire Color |
| Common (+) | Red/Green |
| RED | Red/Black |
| GREEN | White/Black |
| BLUE | Green/Black |
Upper section
| Common (+) | Black/Red |
| RED | White |
| GREEN | Black |
| BLUE | Red |
Lower section
| Common (+) | Orange/Red |
| RED | Orange |
| GREEN | Green |
| BLUE | Blue |
Thermistor
LED Connector
| Pin Number | Wire Color |
| 1 | White |
| 2 | Green |
| 3 | Blue |
| 4 | Red/Black |
| 5 | Orange/Black |
| 6 | Black/White |
| 7 | Green/White |
| 8 | Black/Red |
| 9 | Orange/Red |
| 10 | Red/Green |
| 11 | Black/Red/White |
| 12 | Red/Black/White |
| 13 | Black |
| 14 | Red |
| 15 | Orange |
| 16 | White/Black |
| 17 | Green/Black |
| 18 | Blue/Black |
| 19 | Red/White |
| 20 | Blue/White |
| 21 | White/Red |
| 22 | Blue/Red |
| 23 | Thermistor \ |
Replacement Power Supplies
Replacement Control Modules
Non-OEM replacement for the Control Module options include a DCSSR driven by a controller  such as the REN48LSD, Simple Renard 32 or the REN64.
Another Hint: These units may have been controlled by "ControlFX Initializer Software", a Windows®XP application to set DMX addresses of the luminaires using the ControlFX Initializer hardware interface. ControlFX Initializer Device The DMX 512A standard comprises 255 “alternate START codes”. The START code is the first byte of data transmitted across a DMX network. TIR Systems has registered START code 37 (hex) for its exclusive use. ControlFX TM Initializer Device refers to a piece of hardware produced by TIR Systems that is used to initialize its luminaires using START code 37. Only TIR®luminaires should recognize data sent with a start code of 37.
US Patent 7394210 is a TIR Patent on controlling DMX lights.
The controller essentially performs four functions:
The DMX512 code produced by the SelectFX controller was non-standard, with a non-NULL packet header designed to communicate color effect and timer synchronization information to the Destiny controller.
DMX Address Translation Board
Since these light responds to DMX Channels 1-3 out of the box, a board is under development to respond to any DMX address and translate it to channels 1-3 to drive these floods.  For more info look here.
Documentation
Quick Start Product Guide
Wiring Schematic
Destiny CG Datasheet
TIR Flood Discussion Threads
Initial Thread
Test Pattern
Outdoor Test
Another outdoor test
Other Photos
