Electronics Hardware
Links
SSR Direct Attach
Kit74
Hill320
Olsen 595/Grinch
 - Documentation: Olsen 595
Firegod
 - Documentation: Firegod
Renard
Lynx
- Controlled through: DMX
Helix
 - Documentation: Helix
LedTriks
Triks-C
LEDTRIKS LED PANELS
PIX-C
 - Documentation: PIX-C
JEC Pixel Displays
rgbLED
Color Stick
 - Documentation: Color Stick
- Documentation: Super Strip
RS485 Splitter
FM Transmitters & Antennas
Almost everyone that builds a system to synchronize their lights to music broadcasts that music on a local FM frequency.  This section covers the DIY aspects of FM Transmitters and Antennas.
DMX Boards, both converters and light controllers
This section is under construction, please consider all links broken below
			Renard SS 8
			Renard SS 16
			Renard SS 24
			RPM USB to DMX Adapter
			RPM DMX4 SSR
			RPM DMX16 SSR
			RPM DMX8 DC SSR
			RPM DMX16 DC SSR
Digital Input/Output Cards
