SSRneon-G2-LED
Safety Features
The Schematic can be viewed by clicking on the picture for a larger document:
File:SSRneon-G2-LED Schematic.pdf
Order your own boards
Home Etch
If you want to home etch an SSR, please go to the wiki entry for the SSRneon-G2 which is a home etch friendly design.
Fuse Rating
BOM for 120VAC Operation:
QTY Mouser #: Description
2 606-A9A Neon Lamp 65VAC .7mA NE-2E marked NE1, NE2
1 534-3527C Fuse Cover
4 859-MOC3023 Optocomponents Optocoupler marked IC1, IC2, IC3 and IC4
See above for TA-200 sources.
1 TA-200 Enclosure
Wiring The SSRneon
Controller Output Pinout
