SSRneon TA-200 Versions
Two versions that fit in the TA-200 Enclosure
The SSRneon-G2 is available in two versions, the SSRneon-G2 and the SSRneon-G2-LED. Both of these designs share similar layouts and both have the neon bulb indicators for extra safety. The SSRneon-G2 was available as both a production board and as a home-etchable board. The SSRneon-G2-LED is only available as a two sided production board. There is no home etch layout available.
Safety Features
Order your own boards
Home Etch
Fuse Rating
BOM for 120VAC Operation:
4      571-1-390261-1     IC Sockets 6P ECONOMY TIN  (Optional, but worth every penny)
                          also marked U1, U2, U3 and U4
5      571-2828372        Terminal Blocks 5.08MM PCB MOUNT 2P
See above for TA-200 sources.
240VAC Operation
FireGod
This PCB has a different terminal block ------------------------------------>
Wiring The SSRneon
 Controller Output Pinout
Original SSRneon
