SSRneon TA-200 Versions
The current Version of the SSRneon is SSRneon-G2-LED. This is a variation on the second generation of the SSRneon and was designed to fit in one specific enclosure (TA-200) as detailed below.
Two versions that fit in the TA-200 Enclosure
Safety Features
Order your own boards
Home Etch
Fuse Rating
BOM for 120VAC Operation:
QTY Mouser #: Description
2 606-A9A Neon Lamp 65VAC .7mA NE-2E
1 571-5556416-1 Modular Jacks 8 PCB TOP ENTRY marked RJ45
4 511-BTA04-700T Triacs 4 Amp 700 Volt marked Q1, Q2, Q3, and Q4
1 604-WP7104IT LED Standard HI EFF RED TRANS marked LED
5 660-CF1/4C681J 1/4Watt Axial Carbon Film Resistors 680ohms 5% marked R1, R2, R3, R4 & R11
2 660-CF1/4C104J 1/4Watt Axial Carbon Film Resistors 100Kohms 5% marked R9, R10,
4 859-MOC3023 Optocomponents Optocoupler TRIAC marked U1, U2, U3 and U4
4 571-1-390261-1 IC Sockets 6P ECONOMY TIN (Optional, but worth every penny)
also marked U1, U2, U3 and U4
5 571-2828372 Terminal Blocks 5.08MM PCB MOUNT 2P
See above for TA-200 sources.
1 TA-200 Enclosure
240VAC Operation
FireGod
This PCB has a different terminal block ------------------------------------>
Wiring The SSRneon
Controller Output Pinout
Original SSRneon
