Simple Sound to Servo
Revision as of 05:13, 28 March 2012 by Jklingert (talk | contribs) (BOM)
The Simple sound to servo is an inexpensive controller based on the Scary Terry sound to servo circuit found here http://www.scary-terry.com/audioservo/audioservo.htm This circuit takes an audio source such as an MP3 player and outputs a signal to a hobby servo to move the jaw to the sound on talking props.
Adjustments
Gain: The gain adjustment is used to control the gain of the amplifier to match the controller to your source audio
Threshold: The threshold adjustment is used to calibrate the circuit and set the point of sound or no sound
Max Adj: The max adjust is used to set the maximum servo position when sound is present. You can think of this like a high limit switch
Min Adj: The min adjust is used to set the minimum servo position when sound is not present. You can think of this like a low limit switch.
Capacitor Select: There are 3 capacitors of different values to chose from. The higher the value of the capacitor the more smooth the jaw will move. If you want a more jerky action enable a lower value capacitor or no capacitor at all. The capacitors are arranged lowest to highest value from left to right. Capacitors are enabled by placing a shunt on the jumpers JP4,JP5,JP6 directly above the capacitors.
L/R Select: If you want the board to "Listen" only to the left or right channel of audio install a shunt on either the left or right jumper. If you want it to "listen" to both channels install shunts on both jumpers.
Connections
Setup
Description of operation
From the Scary Terry website
Jeff Stevens solution
Threads and Demo Videos
[Initial thread]
[Demo Video 1]
[Demo Video 2]
[Demo Video 3] with technique for better sound to motion adjustment using high frequency tones.
THE ASSEMBLY INSTRUCTIONS ARE A WORK IN PROGRESS, PLEASE CHECK BACK IN A FEW DAYS WHEN IT IS FINALLY CORRECT
  2. Install the resistors:
    1. Install the 220K ohm resistor (red-red-yellow) at location R9. The resistor is not polarized, so it can go either way.
    2. Install the 1K ohm resistor (brown-black-red) at location R1. The resistor is not polarized, so it can go either way.
    3. Install the 47K ohm resistors (yellow-violet-orange) at locations R2 and R4. The resistors are not polarized, so it can go either way.
    4. Install the 10K ohm resistors (brown-black-orange) at locations R5,R12,R15,R20. The resistors are not polarized, so it can go either way.
    5. Install the 2.2K ohm resistor (red-red-red) at location R14. The resistor is not polarized, so it can go either way.
    6. Install the 470 ohm resistor (yellow-violet-brown) at location R8. The resistor is not polarized, so it can go either way.
    7. Install the 4.7K ohm resistors (yellow-violet-red) at locations R4 and R11. The resistors are not polarized, so it can go either way.
  3. Install adjustment trimpots:
    1. Install the 5K ohm trimpot at location R3. The trimpot only fits one way, with the two legs towards the top of the board.
    2. Install the 1K ohm trimpot at location R6. The trimpot only fits one way, with the two legs towards the top of the board.
    3. Install the 50K ohm trimpots at locations R10 and R22. The trimpot only fits one way, with the two legs towards the top of the board.
  4. Install the IC sockets:
    1. Install the 14 pin IC socket at location IC2. The notch on the socket should face the left side of the board.
    2. Install the 8 pin IC sockets at locations IC1 and IC3. The notch on the socket should face the left side of the board.
  5. Install the 1N914 Diode at location D1. The diode is polarized and it can only go one way. The end with the band (cathode) goes towards the right side of the board.
  6. Install the 2N3904 transistor at location Q1. The flat side of the transistor should face the left side of the board.
  7. Install the capacitors:
    1. Install the 2.2uF electrolytic capacitor at location C5. The capacitor is polarized. The side of the capacitor will have a stripe on the negative side. The long lead is the positive side, and it goes in the hole towards the top side of the board.
    2. Install the 4.7uF electrolytic capacitor at location C2. The capacitor is polarized. The side of the capacitor will have a stripe on the negative side. The long lead is the positive side, and it goes in the hole towards the top side of the board.
    3. Install the 10uF electrolytic capacitor at location C7. The capacitor is polarized. The side of the capacitor will have a stripe on the negative side. The long lead is the positive side, and it goes in the hole towards the top side of the board.
    4. Install the 100nF (0.1uF) mylar capacitors at locations C1,C3,C6,C11. The capacitor is not polarized, so it can go either way.
    5. Install the 10nF (0.01uF) mylar capacitor at location C4. The capacitor is not polarized, so it can go either way.
  8. Install the red LED at location D2. The LED is polarized. There is a flat side (cathode) has a short lead and it faces towards the left side of the board.
  9. Install the jumpers:
    1. Install the 2 pin headers at locations JP1 and JP2. Snap the 2pin header from the longer strip by holding it in pliers and breaking along the lines between the pins. The short side of the jumper strip goes into the board.
    2. Install the 3 pin header at location JP3. Snap the 3pin header from the longer strip by holding it in pliers and breaking along the lines between the pins. The short side of the jumper strip goes into the board.
    3. Install the 6 pin header across locations JP4,JP5,JP6. Snap the 6pin header from the longer strip by holding it in pliers and breaking along the lines between the pins. The short side of the jumper strip goes into the board.
  10. Install the Screw connectors:
    1. Install the 3 position screw terminal block at location X3. The side where the wires enter under the screw should face the bottom of the board.
    2. Install the 2 position screw terminal block at location X2. The side where the wires enter under the screw should face the bottom of the board.
  11. Install the ICs:
    1. Install the LM1458N IC in the 8 pin socket at location IC1. The notch on the IC should face the left side of the board.
    2. Install the CD4066 IC in the 14 pin socket at location IC2. The notch on the IC should face the left side of the board.
    3. Install the NE555 IC in 8 pin socket at location IC3. The notch on the IC should face the left side of the board.
Congratulations, you have just finished building the Simple Sound to Servo! Inspect the board to make sure that you have soldered all connections and that there are no shorts or cold solder joints.
Here is a schematic diagram in pdf format File:Simple Sound to Servo sch.pdf
Board
All parts were sourced from Tayda Electronics 1 BOM will populate 2 Simple Sound to Servo Boards. The BOM is a double order because just one does not meet the $5 minimum order. You will also have a few left over resistors due to the fact that Tayda requires minimum of 10 each value. The only part that I have not tested is the 3.5mm audio Jack. This jack was an after though and is meant to be mounted as a pass thru connector on your enclosure that way you don't need to open the enclosure to plug your audio cable in.
Tayda Electronics
PartLocationQtyPart #Link
220K OHM 1/4W 5% Carbon Film ResistorR910A-2110Link
100nF 0.1uF 100V 5% Mylar Film CapacitorC1,C3,C6,C118A-4110Link
1K OHM 1/4W 5% Carbon Film ResistorR110A-2123Link
47K OHM 1/4W 5% Carbon Film ResistorR2,R410A-2066Link
5K OHM Trimpot Variable Resistor 6mmR32A-2513Link
1K OHM Trimpot Variable Resistor 6mmR62A-2509Link
10K OHM 1/4W 5% Carbon Film ResistorR5,R12,R15,R2020A-2115Link
1N914 Small Signal Diode 200mA 100VD12A-615Link
LM1458N LM1458 1458 IC DUAL OPERATIONAL AMPLIFIERIC12A-286Link
10uF 25V105C Radial Electrolytic Capacitor 5x11mmC72A-4534Link
2.2K OHM 1/4W 5% Carbon Film ResistorR1410A-2087Link
CD4066 4066 IC CMOS QUAD BILATERAL SWITCHIC22A-555Link
470 OHM 1/4W 5% Carbon Film ResistorR810A-2049Link
4.7K 4K7 OHM 1/4W 5% Carbon Film ResistorR4,R1110A-2027Link
50K OHM Trimpot Variable Resistor 6mmR10,R224A-2500Link
10nF 0.01uF 100V 5% Mylar Film CapacitorsC42A-4106Link
NE555 IC 555 Timer DIP-8IC32A-249Link
2.2uF 50V 105C Radial Electrolytic Capacitor 5x11mmC52A-4532Link
4.7uF 16V 105C Radial Electrolytic Capacitor 5x11mmC22A-4529Link
2N3904 NPN General Propose TransistorQ12A-111Link
LED 3mm RedD2,2A-261Link
40 Pin 2.54 mm Single Row Pin Header StripJP1,JP2,JP3,JP4,JP5,JP61A-197Link
DG301 Screw Terminal Block 3 Positions 5mmX32A-669Link
DG301 Screw Terminal Block 2 Positions 5mmX22A-668Link
14 pin DIP IC Socket Adaptor Solder TypeIC22 A-004Link
8 pin DIP IC Socket Adaptor Solder TypeIC1,IC34A-001Link
3.5mm Stereo Enclosed Socket2A-865Link
Total cost for 2 BOMs $5.01
You will also need a few shunts like these from Mouser. Tayda does not carry them or at least I could not find them. I just grab them out of old disc drives and motherboards.
Housing
