Vastelec FM02
Pictures of FM02's in enclosures
Each FM02 installation is unique !
A gallery of pictures and 'how to build notes' showing various FM02 installations is available.
Click Here to see many FM02 installations: FM02_Galleryx Link currently turned off while the page is built.
Do you have a HUM ?
Audio
Schematic and PCB layout
Detailed Board Dimensions
Antenna
How to Make a Dipole Antenna
What Frequency to Use
RDS hookup information
Additional Modifications
PART15:
