Vastelec FM02
When you connect power to the FM02 it is VERY important that you get your positive(+) and your negative(-) correct. If you hook up the power incorrectly, you can easily damage/ruin the unit.
Do you have a HUM ?
Many folks will experience some HUM in the transmitted audio. This is normal. The good news is that you should be able to eliminate this hum with the use of a Ferrite Bead. (See Audio Section below for poor audio quality problems)
Audio
Detailed Board Dimensions
Antenna
How to Make a Dipole Antenna
What Frequency to Use
RDS hookup information
Additional Modifications
PART15:
