Ren-W BOM and Construction
 - 1 -- RS-232 Interface ICs Dual EIA-232 Driver Mouser# 595-MAX232IN
 - 1 -- XBee Wireless RF modules (Pro version w/1" whip antenna is Mouser# 888-XBP24-AWI-001. The SMA version is #888-XBP24-ASI-001)
 - 1 -- Ren-W circuit board (etch your own in the true DIYC spirit, or contact dirknerkle for pre-made boards)
SUBSTITUTE PARTS
- 3.3v voltage regulator: Texas Instruments part # UA78M33CKCS
 - RS-232 chip: Mouser part #: 595-MAX232N
 - RS-232 chip: Mouser part #: 595-MAX232EIN
Rev6 board BOM Differences
- The Rev6 board needs only one RJ45 jack and only two XBee female headers. Otherwise, parts are the same.
 - Here's a direct link to the Express PCB source file for the Rev6 board: Ren-W Rev6 PCB file
 - Here's a direct link to the schematic for the Ren-W board: Ren-W_Schematic.JPG file
PCB Parts Layout
- The only important difference between the standard board and the SMA board is the orientation of the XBee modules. The standard board has the modules pointing upward; the SMA version has them pointing downward to allow for the long RPSMA antenna connector. Pay careful attention to the orientation of the XBee when plugging it into the board. If you have the standard board, plugging in an XBee module with an SMA connector upside-down will NOT WORK. Likewise, plugging in an XBee with a 1" whip the wrong way on an SMA board won't work, either.
- The latest Rev6 version of the board has space for only one XBee module and uses a jumper to make the board be either a transmitter (TX) or receiver (RX). The Rev6 board cannot function as a repeater board as it has only one RJ45 jack, but it is about 30% smaller in size and has fewer parts so it's slightly less expensive to build.
Construction Step-by-step
- The construction steps are identical for both the standard and SMA version of the board, and the Rev6 board uses the same part numbers. Caution - the pins on these headers are quite tiny and require very little solder. Too much solder may flow down and fill the pin hole in the header itself and prevent plugging in the XBee later on.
- 4. OPTIONAL: Solder non-polarized capacitors C4, C5 and C6. Like C1 and C2, if electrolytic capacitors are used, observe the + polarity markings on the board. (Note: C4, C5 and C6 do a lot to clean up the RS-232 signal the Ren-W provides to the Renard controller, and these are essential if connecting the Ren-W to a Ren-C/595 or Ren-C/Grinch.)
- 7.	Solder RJ45 jacks J1, J2
- 8. Solder zener diode D1. Note the polarity – on the SMA board, the band on the diode must be facing up, next to header JP6. On the Rev6 board the band on the diode must be facing DOWN, next to header H2.
- 11. Solder the 3.3v voltage regulator U1. On the SMA board the metal heat sink side faces toward JP2 (top); on the Rev6 board the metal heat sink side faces toward C3 (right). The need for an additional heat sink is highly unlikely as the supply voltage is only 5vdc. At this point, applying power to the SMA board should light the LED (if installed) and the voltage test points in the middle of the board should register the proper voltages. The Rev6 board requires that the XBee radio be in the sockets; the LED will then blink showing the XBee radio is operational. Disconnect power before continuing with the next step.
- 17. REV-6 board only: install 2-pin jumper headers at the TX and RX locations.
Powering the Ren-W board
- A nifty solution that retains the SS controller’s ability to use the diagnostic LEDs is to solder each end of a single strand of cat5 wire to an open jumper shunt such as the photo above. Alternately, you may wish to make your own power cable using two female SL connectors; use a small piece of shrink tubing around the connector for insulation safety. (Both pins on the Ren-W’s JP3 header are +5vdc; both JP4 pins are ground connections.)
- With WayneJ's SS line of boards, the Ren-W draws its +5vdc power from the left pin of the board’s JP3 header (photo above); the ground power connection is made when the Ren-W is connected to either of the SS controller's RJ45 jacks. If you used the open jumper shunts to make your cable, simply plug the shunts into the JP3 headers on both the SS controller and the Ren-W.
- With Frank Kostyun's Ren24 ver 3.3, +5vdc can be taken at TP2 (test point 2). You may drill a small hole in the pad if you wish to solder-in a single pin header. With the Ren24LV (photo above) the red circles show places where 5vdc can be found: TP2 and the "Power Tie" (both circled in red in the above photo). The power tie includes six places for jumper header pins, the TOP LEFT of which carries +5vdc (red arrow) Remember, ground is made automatically when the cat5 cable is plugged in.
- With Wjohn's Ren64 (version XC5) there is a small, unmarked +5vdc test point immediately below pin 8 of U5 (the rightmost ST485BN chip) and just left of R14. Solder-in a single header pin if you like such as the example above (red circle).
- With Wjohn's Ren-C, +5vdc can be taken from the header pin immediately to the left of the Q1 transistor. The pin is marked VCC. Another +5vd VCC location is the 2nd from the top pin of the 6-pin JP6 programming header. Either location is fine. Both are marked with red arrows in the photo above.
- With Budude's Ren48LSD, if you power the LSD board with 12vdc or less you can solder a single header pin into the test point that's next to the .1uf capacitor that resides between the voltage regulator and the 2200uf capacitor. The Ren-W's voltage regulator may get a bit warm but the MAX232 chip can handle 12vdc power and you should be okay. However, if you power the LSD board with more than 12vdc, you must tap power from the +5v side of one of the .1uf capacitors connected to pin 1 of any of the PIC16F688 chips. While not as handy as using the test point, it's a safer and more accurate way to power the Ren-W from the Ren48LSD.
 - On the SS controller, you may find that the board functions better with JP1 not jumpered (RS-485 mode)but JP2 is jumpered. You can always try JP1 jumpered, but it may not be as effective.
- Rev6 board only: since this board has only one RJ45 jack (J2), it can be plugged into either the J1 or J2 jack on the Renard controller. If using the Rev6 as a receiver, place a jumper shunt on the RX header and connect J2 to the RS INPUT jack of the controller. If using the Rev6 as a transmitter, place a jumper shunt on the TX header and connect the Rev6's J2 to the RS OUTPUT jack of the controller. Note that the Rev6 board cannot be used as a "repeater" board which both receives and retransmits out. However, it can be used to transmit from a wired Renard controller to another Ren-W. Of course, a Rev6 can also be a main transmitter board at the PC as well. IMPORTANT: Rev-6 works best when JP2 (the termination resistor) on the SS board is open and not shunted.
Other Voltage Test Points
Economy Ren-W Construction
- If you know exactly how many receive-only and/or transmit-only boards you need and want to save some cash, you can economize by not populating the board with parts that will not be used. For example, below are pictures of stripped-down yet fully functional transmit-only (left) and receive-only (right) boards. Note the parts that are missing on each board. These examples also show the standard XBee radio, not the Pro version, which cuts cost even more, although the standard XBee is quite limited in transmission range. (Price comparison: the Standard Xbee is $19, XBee Pro is $32, XBee Pro with SMA connector is $34.):
- Bottom line: a fully-populated Ren-W board totals about $43.38 for parts with the XBee Pro radio. If you don't need the extra power of the Pro version and opt for the standard XBee, you could build a transmit-only or receive-only board for about $26. Home-etch the boards yourself and you could have a fully-functional two-station system for about $50, and using the XBee Pro version would cost only $26 more for the pair. So if you're on the fence about wireless, you can see that it doesn't have to cost an arm-and-a-leg.
