Vastelec FM02
- Power. A regulated 12v DC power supply is needed. 100ma is enough current.
About VAST Electronics
DO NOT apply anything GREATER then REGULATED 9V-16V DC to your unit. If you aren't sure, then ask for help in the forums. Use a meter to check the voltage first. If all you have is a wall-wart that is labeled 12V, then that is most likely NOT regulated. A simple test of the output voltage with a meter will tell the tale. I use one of the voltage regulators from Sure Electronics with my unit (Part number:PS-SP12113). These are about $5 online.
When you connect power to the FM02 it is VERY important that you get your positive(+) and your negative(-) correct. If you hook up the power incorrectly, you can easily damage/ruin the unit.
Do you have a HUM ?
Many folks will experience some HUM in the transmitted audio? This is normal. The good news is that you should be able to eliminate this hum with the use of a Ferrite Bead.
Sometimes, it helps to put a ferrite bead on the audio cable between the PC and transmitter. NOTE: it never hurts to put one or more ferrite beads on your cables. They may or may not eliminate your HUM, but they never make it worse.
Detailed Board Dimensions
Antenna
How to Make a Dipole Antenna
What Frequency to Use
