Vastelec FM02
- Power. A regulated 12v DC power supply is needed. 100ma is enough current.
About VAST Electronics
DO NOT apply anything GREATER then REGULATED 12V DC to your unit. If you aren't sure, then ask for help in the forums. Use a meter to check the voltage first. If all you have is a wall-wart that is labeled 12V, then that is most likely NOT regulated. A simple test of the output voltage with a meter will tell the tale. I use one of the voltage regulators from Sure Electronics with my unit (Part number:PS-SP12113). These are about $5 online.
Many folks will experience some HUM when using a wall wart for power that is then regulated via voltage regulator. This is normal. The good news is that you should be able to eliminate this hum with the use of a Ferrite Bead.
As far as size, you want to be able to wrap the wire through the hole and around the perimeter 3 times for maximum effect. You also need to wrap it tightly and secure it in place with a nylon tie wrap. So, it depends on the size of the wire that comes out of your wall wart, you need to have a diameter that can fit three wraps of the wire and the tie. Do this picture three times: (some of these split in half, some don't !)
There are some good pictures in the wiki-pedia-: http://en.wikipedia.org/wiki/Ferrite_bead
Detailed Board Dimensions
Antenna
How to Make a Dipole Antenna
What Frequency to Use
