Vastelec FM02
The FM02 is a two board FM transmitter.  It accepts a stereo audio source and outputs a stereo FM broadcast signal on the frequency shown on the LED display.  It comes just as shown in the picture above.
About VAST Electronics
Detailed Board Dimensions
Here is a pdf file that contains a scale outline that will serve as a template for the display board. You would use this to create your own bezel if you want to dress-up your installation: Media:FM02_cutout_layout.pdf
Antenna
What Frequency to Use
This is real simple, go to this website and find a frequency that is unused. If there are no unused frequency's, then pick one that is not very powerful and get your radio out and check it out. If you can't pick it up at your house, odds are no one will complain when you start broadcasting on that frequency.
