SSRneon
- the images shown of the board layout will be replaced with pictures of the actual PCB ***
 - once the boards from the first coop have been received. ***
Safety Features
The main safety feature of any SSR is the main FUSE. This is discussed in a separate section below.
The SSRneon contains two NE-2E neon light bulbs. These lights are what differentiates the SSRneon from the other available SSRs.
Home Etch
The copper image can be found here: The silkscreen image can be found here: The image of the product board can be found here:
Fuse Rating
Various fuse values have been listed for all the various 4 port SSRs. e.g. Sean Bowf, SSRoz, SSRez.
4      571-1-390261-1     IC Sockets 6P ECONOMY TIN  (Optional, but worth every penny)
                          also marked U1, U2, U3 and U4
5      571-28228372       Terminal Blocks 5.08MM PCB MOUNT 2P
*Note regarding resistors.  You usually want to purchase resistors from Mouser in quantities of 100 of a specific value.  You usually can get 100 resistors for the same price of 20 individual resistors.  (You will eventually use them !)
See above for TA-200 sources.
Now the above is the base Bill of Materials for 120VAC operation. Other Source Voltages are possible. These are listed below.
240VAC Operation
FireGod
15. Install the fuse.
Wiring The SSRneon
The following image shows how to connect wires to the SSRneon.
Original SSRneon
The original SSRneon was not designed for any particular enclosure. It has only one neon bulb to signal the presence of AC before it passes through the fuse. You must also wire a 100K resistor inline with the single neon bulb leads because there is no separate attachment point for the resistor.
