Renard Data Cables
The data cables shown on this page apply to the current Renard board designs at DIYC, except the  Renard 16 (xmus) which has unique requirements.
 Some earlier designs/prototypes may have different cable requirements, when in doubt check the dedicated wiki page for that particular board.
Data Cables
Directly to computer COMM port (DE9 to DE9 connection)
Mainly for Renard 64XC and Renard SS boards PC DE9 Pin 3 to Renard DE9 Pin 3 PC DE9 Pin 5 to Renard DE9 Pin 5
Directly to computer COMM port (DE9 to RJ45 connection)
Directly to computer COMM port via Cisco Console Cable (DE9 to RJ45 connection)
Step 1. Cut the existing RJ-45 end off. Step 2. Install a new RJ-45 end with the cables in the following order: PC DE9 Pin 3(Green) to RJ45-pin 4 PC DE9 pin 5(Yellow & Orange) to RJ45-pin 5 and pin 1
Using a RS232->RS485 or USB->RS485 converter
In a DMX environment
Connecting multiple Renard boards
Generally only a regular straight-thru CAT5 cable is required to connect a Renard board to other Renard boards. For the few exceptions (ie Ren24 V2.5), check the wiki page for those boards to see what their unique requirements are.
Adapters/Converters
Note to reader: The following adapters are examples of some of the common adapters that are available on eBay and other on-line sources. All of these adapters were tested during the writing of this wiki page. But since most of the sources for these adapters are in China, the quality of any given product may vary greatly. So while this batch of adapters worked there are no guarantees that future items from China will perform also, so please do not blame the author of this page if you happen to get an adapter that doesn't perform well.
DE9 to RJ-45 Adapter
- This easy to use adapter is great for converting from the serial DE9 connector on most computers/adapters to a CAT5 RJ-45 connector. This allows you to use normal CAT5 cables to connect your computer to the controllers.
- Below is what appears to be the common color coding for the RJ-45 pin assignments. While all samples that were found during the writing of this article followed the same color coding, you should always double check any adapters that you might decide to use.
- Modification for using this adapter for RS-232
- Remove the wires for unused pins (3-black, 6-yellow, 7-brown, 8-white). Cut the wires off as far down in the adapter as possible because you will need one of these wires later.
 - Cut the pins off of wires for pin 1-blue, 2-orange, 5-green.
 - Solder the above wires together, along with one of the wires cut off in the first step.
 - Use some heat shrink tubing to cover the soldered area.
 - Insert the pin on the wire connecting the soldered together wires into DE9 connector pin 5.
 - Insert the pin on the red wire (RJ45, pin 4) into DE9 connector pin 3.
- Modification for using this adapter for common RS-485 adapters
 - Cut the pins off of wires for pin 1-blue, 2-orange.
 - Insert the pin on the red wire (RJ45, pin 4) into DE9 connector pin 1.
 - Insert the pin on the green wire (RJ45, pin 5) into DE9 connector pin 2.
USB to RS-232 Converters
- The output connector of each converter above is the same, so the converters are hooked-up in the same fashion.
USB to RS-485 Converters
Adapter board signal T-/A connects to RJ45-pin 4 (blue CAT5 wire) Adapter board signal T+/B connects to RJ45-pin 5 (blue/white CAT5 wire) Adapter board GND signal connects to RJ45-pins 1 & 2 (orange and orange/white CAT5 wires)
RS-232 to RS-485 Converters
Adapter board signal T/R- connects to RJ45-pin 4 (blue CAT5 wire) Adapter board signal T/R+ connects to RJ45-pin 5 (blue/white CAT5 wire) Adapter board GND signal connects to RJ45-pins 1 & 2 (orange and orange/white CAT5 wires)
Adapter board signal 485+ connects to RJ45-pin 5 (blue/white CAT5 wire) Adapter board signal 485- connects to RJ45-pin 4 (blue CAT5 wire) Adapter board GND signal connects to RJ45-pins 1 & 2 (orange and orange/white CAT5 wires)
Adapter board signal D+/A connects to RJ45-pin 5 (blue/white CAT5 wire) Adapter board signal D-/B connects to RJ45-pin 4 (blue CAT5 wire) Adapter board GND signal connects to RJ45-pins 1 & 2 (orange and orange/white CAT5 wires)
- All the above RS-232 to RS-485 adapters have the same pin configuration of the output connector, so they all can use the same modified DE9 to RJ-45 adapter.
