Renard64
Layout
PCB
1  TBA                   Renard 64-Port PCB
Resistors
3  299-27K-RC            27K Resistor, 1/4 W, Axial (RS485 pull)     R5,R8,R14
2  299-1K-RC             1K Resistor, 1/4 W, Axial (RS485 series)    R4,R7
1  660-MF1/4DCT52R1200F  120 Resistor, 1/4 W, Axial                  R6
1  299-330-RC            330 Resistor, 1/4 W, Axial (for LED)        R19
2  71-CCF60-15K-E3       15K Resistor, 3/4 W, MF Resistor            R1,R2
Capacitors
8  80-C322C104K5R        0.1 uF Radial-lead Ceramic Capacitor        C3-C10
1  647-UVR1C100MDD       10 uF, 16V Radial-Lead Elect. Cap           C2
Diodes
1  78-1N5229B            4.3v 0.5w Zener                             D4 (left)
1  78-1N5239B            9.1v 0.5w Zener                             D4 (right)
1  604-WP7104GT          T1 Green LED                                D5
Connectors
2  571-5202514           AMP Modular Jacks, Right Angle              J3, J4
16 571-5564161           AMP Modular Jacks, Top Entry                J5-16, J18-21
         or
16 538-95003-2881        Molex Modular Jacks, Vertical PCB mount
2  571-6404542           AMP Polarized Header (2-Pin, Straight Post) J1,J17
8  575-199314            14 Pin Low Profile IC Socket                U7-U14
ICs
1  782-H11AA1            Optoisolator                                U6
2  511-ST485BN           RS485 Connectors                            U4,U5
8  579-PIC16F688-I/P     PIC16F688, unprogrammed, DIP14, Industrial Temp    U7-14
Oscillator
1 520-TCH1843-X          Oscillator, 18.432 MHz, 5V, 8-DIP           U3
Optional (if per/port LEDs are desired)
64 859-LTL403G           LEDs, Rectangular, Green
8  71-CSC08A01-680       Resistor Network, 680 Ohm                   R10-13, R20-23
8  299-680-RC            Resistor, 680 Ohm, 1/4W                     R15-18, R24-27
Optional (if per/port LEDs are omitted, the non-PWM firmware is used, and unregulated power is brought in through the RJ45 input connector)
1  625-1N5819-E3         50v 1A Schottkey Diode                      D1
1  511-L4940V            Regulator, LDO, 5V, 1.5A                    U1
1  140-XRL16V1000-RC     1000 uF, 16V Radial-Lead Elect. Cap         C1
The on-board regulator should only be used if measures are taken to keep the current consumption down (omitting the on-board LEDs, and using the non-PWM firmware). If the LEDs are used and the PWM firmware is installed, the current consumption if the board is about 1A, and so the regulator will dissipate too much power (the small value of C1 precludes decreasing the input voltage).
7/21/2007 BOM copied from picdimmer forum, on-board regulator made optional 7/21/2007 Value of regulator parts (diode, regulator, cap) changed. 7/21/2007 Value of LED current limit resistors changed.
Errata for Rev XA PCB -
1) The trace between J4 and D1 is too small, and needs to be beefed up if the board is configured to draw more than 1/2A through J4. 2) There are two diodes labelled D4. 3) The holes for D1 are too small. 4) The silkscreen reference designator for C3 (above U10) is missing.
