Renard8
First PCB Revision
This board can be distinguished by the letters XA on the solder side of the board, and by not having any silkscreen or soldermask.
This schematic is intended to exactly represent the first revision of the PCB. As such, the board has three known issues that will be changed on the next revision of the PCB (if there is one).
1) The order of the outputs on J4, J5 is exactly reversed from that of the Renard16, Renard64 and other Renard boards. Output 1 appears on the connector (J5, pin 8) where Output 8 would be expected (based on the other boards) instead of the expected location (J4, pin 2), and so forth. The power and ground connections are in the proper and expected location on these connectors.
2) The RS232/RS485 connections on pins 4,5 of J1 and J2 are transposed with respect to the other boards.
3) The input biasing resistors (R5, R6) are connected wrong, so that they force the serial input on the PIC to go low when the input cable to the board is disconnected. This does not appear to cause any problems at the time.
PCB Image
The blue layer is the solder side, and the red layer represents the component side. The silkscreen layer is shown on this composite image to indicate where the various components are located. None of the boards manufactured to date actually include the silkscreen or soldermask layers.
Note: this BOM is slightly different from the previously published versions. The preferred part for diode D3 is now a BAT42 diode, because it has lower forward voltage drop and will fit in the holes on the board better. The old parts can continue to be used on previously assembled and working boards. In addition, the regulator is now specified as a LP2950, although you may substitute a LM79L05 if the input voltage to the board is high enough.
The part numbers in this BOM take precedence over those in the schematic above.
PCB
1  TBA                   Renard8 PCB
Resistors
3  299-27K-RC            27K Resistor, 1/4 W, Axial                       R5, R6, R8
2  299-1K-RC              1K Resistor, 1/4 W, Axial                       R3, R4
1  660-MF1/4DCT52R1200F  120 Resistor, 1/4 W, Axial                       R1
1  299-330-RC            330 Resistor, 1/4 W, Axial                       R7
1  299-10K-RC            10K Resistor, 1/4 W, Axial                       R2
Capacitors
1 80-C322C104K5R         0.1 uF Radial-lead Ceramic Capacitor             C2
1 140-XRL16V1000-RC      1000 uF, 16V Electrolytic Capacitor              C1
Diodes
1  78-1N5229B            4.3v 0.5w Zener                                  D2
1  78-1N5239B            9.1v 0.5w Zener                                  D1
1  625-BAT42             30V 100mA Schottky Diode (preferred)             D3
                             or
1  625-1N5819-E3         50V 1A Schottky Diode (not preferred)            D3
                             or
1  625-1N4001-E3         50v 1A Diode (not preferred)                     D3
                             or
1  625-1N4148-E3         50V, 100 mA Diode (not preferred)                D3
1  604-WP7104GT          T1 Green LED                                     D4
Transistors
1  512-2N3904TA          Small Signal Transistor                          Q1
Connectors
4  571-5202514           AMP Modular Jacks, Right Angle                   J1, J2, J4, J5
         or
4  571-5564161           AMP Modular Jacks, Top Entry
         or
4  538-95003-2881        Molex Modular Jacks, Vertical PCB mount
1  575-199314            14 Pin Low Profile IC Socket                     XU3
ICs
1  595-SN65LBC179PE4     RS485 Receiver/Transmitter 65LBC179              U1
1  579-PIC16F688-I/P     PIC16F688, unprogrammed, DIP14, Industrial Temp  U3
1  ---                   Regulator, 5V, Low Power LP2950ACZ-5.0           U2
There isn't a mouser part number specified for the regulator because they are only available in large quantities.  It is available from other sources, and there are other regulators available that should work.
Second Revision
TBA
