4 Channel SSROZ Assembly Instructions
Background
I was a late starter to the CC.com website last year and missed out on Sean Bowf's COOP for SSRs and decided that I would go ahead and make some of my own. This SSR design is a result of collaboration with Sean in January and February 2007, making sure that this design follows the guidance for SSRs as published on www.simpleIO.com and my calculations and testing.
The SSROZ design is currently in it's 4th iteration.
Prototype SSROZ 2.5a
Version History
SSROZ 2.5a, was the first. This is a single side board, 2.2 x 2.0 inches, dated Jan 2007. A small production batch were made and distributed in Australia.
SSROZ 2.5d, Main Production run, based on 2.5b. Mouser vertical fuse holder, 315 mil pins. Yellow silkscreen are ROHS are now standard. Boards are marked 2.5d and dated 21 Jun 2007. This board is designed for the US Market.
Schematic Diagram
Parts List
The parts list for all versions of the SSROZ are common, except for the fuse holder used on the PCB. I have designed two different boards (as detailed above); one for the US market using the Mouser Vertical Fuse holder, and one for the Australian Market using a Jaycar Vertical Fuse holder. Either fuse holder can be used on either board, you will just need to bend the pins of the Fuse Hodler in or out 85 mils if you have the alternate board to the fuse holder you purchased. This is not a big issue, however feedback i received from users said that they would prefer not to bend the fuse holder pins. Hence the two variants; 25.c and 2.5d.
1 RJ-45 Socket
1 LED (red) 3 or 5 mm
1 LED current limiting resistor, 680 ohm, 1/4 watt, 5%
4 Optoisolators MOC 3023M
4 TRIACs (BTA-400 or BTA-600)
4 Optoisolator current limiting resistors, 680 ohm (or 750 ohm), 1/4 watt, 5%
4 TRIAC gate current limiting resistors, 180 ohm, 1/4 watt, 5% *****
1 Fuse holder, vertical (Jaycar or Mouser)
1 2 pole Euro Style screw connector, 5mm pin spacing
1 3 pole Euro Style screw connector, 5mm pin spacing
1 PCB SSROZ 2.5 (c or d)
I have shown the Gate Resistor value as 180 ohm. This is specified for 120VAC operation, for 240VAC operation use 330 ohms.
