Ren48LSD
Ren48LSD Construction Manual
What is the Ren48LSD?
The Ren48LSD controller came about as a solution to drive Frank's LED Super Strips. Originally I used DCSSRs to drive them and while it's a workable solution, it tends to be somewhat bulky and requires lots of additional wiring between the controller and DCSSRs as well as to the strips themselves. Another alternative is Frank's Ren24LV which uses ULN2803 drivers. The issue with this solution is that it has limitations in how much power it can sink to the strips due to the ULN2803 package power dissipation. By the way – 'LSD' stands for LED Strip Driver.
The strips require up to 360mA per output (18 LEDs x 20mA) so I used an NPN bipolar transistor to drive them. The transistors support up to 600mA so there's plenty of headroom left. The transistors are fairly cheap so it makes for a simple, inexpensive solution. The controller design used the Ren24SS as a base, using the same PIC, clocking and serial interface configuraion but expanded to 6 PICs to support 48 channels or driving up to 12 strips per board. Because of this, the controller supports standard Renard protocol FW using RS-232/485 as well as the DMX version. The board requires either a 5vdc well regulated supply or a good 9- 12vdc supply. The input supply also drives the LED strips.
Ren48LSD Parts
| Mouser BOM | ||
| 579-PIC16F688-I/P | Microcontrollers (MCU) 7KB 256 RAM 12 I/O | 6 |
| 571-1-390261-3 | IC & Component Sockets 14P ECONOMY TIN | 6 |
| 863-MPS2222AG | Bipolar Transistors 600mA 75V NPN | 48 |
| 511-L7805CV | Linear Regulators - Standard 5.0V 1.0A Positive | 1 |
| 604-WP7104IT | Standard LED - Through Hole HI EFF RED TRANS | 1 |
| 80-C322C104K5R | Multilayer Ceramic Capacitors (MLCC) - Leaded 50volts 0.1uF 10% | 10 |
| 299-1K-RC | Carbon Film Resistors 1.0Kohms | 2 |
| 299-470-RC | Carbon Film Resistors 470ohms | 48 |
| 299-10K-RC | Carbon Film Resistors 10Kohms | 6 |
| 571-5520251-4 | Telecom & Ethernet Connectors 8/8 SIDE ENTRY | 14 |
| 571-7969492 | Terminal Blocks 5.08MM VERTICAL 2P wire protector | 2 |
Building the Ren48LSD
<PICTURE 1 HERE>
<PICTURE 2 HERE>
<PICTURE 3 HERE>
- Install the six 14-pin PIC chip sockets
 - Install the two 8-pin 485 chip sockets
<PICTURE 4 HERE>
 - Install the ten decoupling capacitors near the IC sockets, oscillator and regulator
<PICTURE 5 HERE>
<PICTURE 6 HERE>
- Install the two 2-pin shunt jumpers (note picture shows only one installed)
 - Install the 5v regulator (OPTIONAL)
 - Install the large capacitor – note correct orientation
<PICTURE 7 HERE>
- If you are not using the 5v regulator then you need to install a jumper across the input/output of where the regulator goes. A 1/2W resistor lead is good for this but any 18-20 gauge wire is fine.
<PICTURE 8 HERE>
- Install the fourteen RJ45 jacks – note that top-entry jacks can be subsituted
 - Mount the 5v regulator heat sink if you installed the regulator – use a small amount of heat sink compound
<PICTURE 9 HERE>
Initial Testing
The first thing you will want to do in any PCB construction project is to double check that you have all components installed and in the proper orientation. You will then want to inspect the board for any cold/bridged solder joints. Take your time with this step and go over each an every joint.
Connect your power supply the “DC IN 1” - it supplies power to controller portion of the board as well as strip outputs 1-6. “DC IN 2” is a separate input to drive strips 7-12. Note that the ground is shared between the two inputs. Turn on the supply and verify the power LED lights up. Verify you have 5v between pins 1 and 14 on each PIC socket as well as between pins 5 and 8 on the 485 chips.
Renard Protocol
Make the following changes:
Renard-DMX Protocol
Obtain the standard Renard firmware from here:
#define DMX_START_ADDRESS 1
Final Testing
- Common +DC
 - Red Ground
 - Common +DC
 - Blue Ground
 - Common +DC
 - Green Ground
 - Common +DC
 - White Ground
Q1: Can this use 24vdc?
A1: The board was not designed to use 24vdc – however it may be possible but requires some hacking to work. The issue is with the 5v regulator that it will get very hot at 24vdc input even with a heat sink. One option would be to install a resistor between the +DC input and the input leg of the regulator of sufficient size/wattage to drop the input voltage to the regulator to keep it cooler. This is similar to what is done with the Ren24LV. I have not tested this myself but with a bit of expermentation, should not be hard to determine. Since the current draw is much higher with this (post regulator) than the 24LV and it won't be the same value.
Here is the first draft of the Ren48LSD Constuction Manual in PDF format - File:Ren48LSD-Manual.pdf
