Ren-W BOM and Construction
PCB Parts Layout
Construction Step-by-step
- 3. Solder capacitors C1 and C2. You may wish to straighten the leads to fit the holes better. (Note: Either non-polarized or electrolytic types are okay. No polarity concerns for non-polarized capacitors. However, if electrolytic capacitors are used, observe the + polarity markings printed on the board for your convenience.)
- 4. OPTIONAL: Solder non-polarized capacitors C4, C5 and C6. Like C1 and C2, if electrolytic capacitors are used, observe the + polarity markings on the board. (Note: C4, C5 and C6 do a lot to clean up the RS-232 signal the Ren-W provides to the Renard controller, and these are essential if connecting the Ren-W to a Ren-C/595 or Ren-C/Grinch. However, in testing, C4, C5 and C6 were unnecessary when using the Ren-W with Renard SS controllers.)
- 5. Solder electrolytic capacitor C3. Note the polarity: the + side into the square pad (top) closer to jack J2.
- 7.	Solder RJ45 jacks J1, J2
- 12. Install the MAX232 and XBee module(s) in their respective sockets. Note the position of pin 1.
- 14. Install optional jumper shunt at JP5 if necessary. This makes the Ren-W into an E-Mode repeater where a single XBee module in the TX position serves as both the receiver and re-transmitter.
- 15. CAUTION: DO NOT place jumper shunts across JP1 or JP2!
- 16. CAUTION: DO NOT place jumper shunts across either pin of JP3 to either pin of JP4!
Powering the Ren-W board
- The Ren-W draws its +5vdc power from the Renard SS board via the left pin of the Renard’s JP3 header; the ground power connection is made when the Ren-W is connected to either of the SS controller's RJ45 jacks. A nifty solution that retains the SS controller’s ability to use the diagnostic LEDs is to solder each end of a single strand of cat5 wire to an open jumper shunt (see photo to the right) and simply plug the shunts into the JP3 headers on both the SS controller and the Ren-W. Alternately, you may wish to make your own power cable using the two female SL connectors; use a small piece of shrink tubing around the connector for insulation safety. (Both pins on the Ren-W’s JP3 header are +5vdc; both JP4 pins are ground connections.)
 - Ren-W as a standard repeater: connect J1 to J1 and J2 to J2 on the SS.
 - Ren-W as an E-mode repeater: connect J1 to J1 and J2 to J2 on the SS, add a jumper on the Ren-W’s JP5 and make sure the Ren-W has only a single XBee module plugged into the TX (left) position.
 - If connecting to the RS-IN of a Ren-C, be sure to include at least one balun on the cat5 cable.
Other Voltage Test Points
