Ren-W BOM and Construction
 - 5 -- 1 uf capacitors (non-polarized - C1, C2, C4, C5, C6) Mouser# 810-FK24Y5V1H105Z (Note: 1 uf electrolytic capacitors may be substituted if you wish; observer proper polarity markings if you use the electrolytics.)
Step-by-step Construction
 - 2. Solder the 16-pin DIP socket into the MAX232 location (skip if no socket is used and the MAX232 is to be soldered directly to the Ren-W board) .
 - 3. Solder capacitors C1, C2, C4, C5, C6. (either non-polarized or electrolytic types are okay. No polarity concerns for the non-polarized capacitors., However, if electrolytic capacitors are used, observe the + polarity markings on the board.)
 - 4. Solder electrolytic capacitor C3. Note the polarity: the + side into the square pad (top) closer to jack J2.
 - 5. Solder 2-pin headers JP1, JP2, JP3, JP4, JP5, JP6. (Note: JP1 and JP2 are optional.)
 - 6.	Solder RJ45 jacks J1, J2
 - 7. Solder zener diode D1. Note the polarity – the band on the diode must be facing up, next to header JP6.
 - 8. Solder resistors R1 (orange-orange-black) and R2 (brown-black-red). R2 is only required if the optional power LED (D2) is used. No polarity concerns.
 - 9. Solder the optional power LED at position D2. Note the polarity – the flat side/cathode/shorter lead faces to the mounting hole immediately to the right of D2.
 - 10. Solder the 3.3v voltage regulator U1. The heat sink side faces toward JP2 (top). The need for an additional heat sink is highly unlikely as the supply voltage is only 5vdc.
 - 11. Install the MAX232 and XBee module(s) in their respective sockets. Note the position of pin 1.
 - 12. Install optional jumper shunts at JP5 and JP6 if necessary (see documentation).
Powering the Ren-W board
- The Ren-W draws its +5vdc power from the Renard SS board via the left pin of the Renard’s JP3 header; the ground power connection is made when the Ren-W is connected to either of the SS controller's RJ45 jacks. A nifty solution that retains the SS controller’s ability to use the diagnostic LEDs is to solder each end of a single strand of cat5 wire to an open jumper shunt (see photo to the right) and simply plug the shunts into the JP3 headers on both the SS controller and the Ren-W. Alternately, you may wish to make your own power cable using the two female SL connectors; use a small piece of shrink tubing around the connector for insulation safety. (Both pins on the Ren-W’s JP3 header are +5vdc; both JP4 pins are ground connections.)
 - Ren-W as a standard repeater: connect J1 to J1 and J2 to J2 on the SS.
 - Ren-W as an E-mode repeater: connect J1 to J1 and J2 to J2 on the SS, add a jumper on the Ren-W’s JP5 and make sure the Ren-W has only a single XBee module plugged into the TX (left) position.
 - If connecting to the RS-IN of a Ren-C, be sure to include at least one balun on the cat5 cable.
Other Voltage Test Points
