Troubleshooting Guide The Renard SS16
- This page is intended to help identify/isolate some of the common problems individuals encounter when building/operating the Renard SS16 controller board.
Basic Troubleshooting Info
Verify Setup
- Verify that the Renard SS16 is assembled correctly as compared to the Renard SS16 Controller Assembly Instructions wiki.
- Verify that you have power/control cables connected correctly as compared to the Renard SS16 Controller wiki.
- Verify that you have the Vixen plug-in settings correct as compared to the Renard SS16 Controller wiki.
Most Common Problems
- Bad data cable coming from the computer. Many individuals assume that all serial cables are identical, but that is far from the truth. Just because a cable has the correct DE9 connectors on each end doesn’t mean that the wires inside are going to the correct pins for Renard operation. It is always best to physically check the pin continuity to verify that the cable will work for Renard operation.
- PICs with corrupted firmware or no firmware. This mostly affects individuals who get their PICs from a “group buy” with the firmware already loaded but also does impact those who program their own PICs. For whatever reason, sometimes a PIC (believed to be correctly programmed) will not behave correctly and needs to be re-flashed with the firmware. Once it is re-flashed then it works correctly. This is why all individuals who are using these boards should invest in a PIC programmer. A programmer will also enable you to switch to the diagnostics firmware, which will help tremendously during troubleshooting.
- Incorrect Vixen Settings. It cannot be emphasized enough, the Renard boards will not work correctly if Vixen is not setup correctly. Verify that you have the Vixen plug-in settings correct as compared to the Renard SS16 Controller wiki.
Renard SS16 Troubleshooting Flow
Troubleshooting Power Problems
Symptom(s):
- LED not lit
 - IC Chips hot to the touch
Possible Problem(s):
- No input voltage present
 - Transformer bad
 - Voltage Regulator bad
 - LED installed backwards
 - Blown fuse
Troubleshooting Steps
- Remove power from Renard SS16
 - Disconnect all cables.
 - If installed, remove all 21 IC chips from their sockets (U2, U4 thru U7, and M1 thru M16).
 - Turn ON AC power.
 - Did the fuse blow?
- If it did, go to step 17
- If incorrect, go to step 13
 - Did the PWR LED light?
- If it did, go to step 21
- Voltage should be approx. 2.0-3.0 VDC.
- If correct, then either the LED is installed backwards or is bad
- If correct, then double check the value of R6
 - Measure AC voltage between  top side of F1 and any N terminal.
 - Measure AC voltage between  bottom side of F1 and any N terminal.
 - Turn OFF AC power
 - Remove F1
 - Turn ON AC power
 - Recheck AC voltage between  bottom side of F1 and any N terminal.
 - Bad/shorted triac
 - Turn OFF AC power
 - Install one of the IC chips (U2, U4 thru U7, and M1 thru M16) into its respective socket.
 - Turn ON AC power
Troubleshooting Diagnostics Problems
Symptom(s):
 - HB and ZC LED do not flash
 - FE and/or OE LEDs light
- Oscillator bad
 - Zero Cross signal bad
 - Vixen settings incorrect
 - PIC bad
- Turn OFF AC power
 - Remove PIC chip U6
 - Turn ON AC power
 - PWR LED should be lit
- If incorrect , then go to the Troubleshooting Power Problems Steps.
 - The  Beta Renard Diagnostic Firmware should perform the following channel test:
- Verify that the LEDs are operational
 - If no LEDs/channels came on,then either the PIC is bad or you have no DC power to the PIC.
 - If any (but not all) LEDs did not come during the step 10 routine, then go to the verifying diagnostic LEDs steps
 - If you used lights hooked up the channels and they did not respond correctly, then go to troubleshooting SSR circuitry problems
- Measure voltage at U6 pin 4 or U2 pin 5, should only be approximately .3 VDC.  If you have an oscilloscope, you should see a signal like the purple trace in this  image.
- Replace U2
 - Check the values of R1 & R2
REMINDER:
The Renard SS16 Controller Board wiki page.
 - Run a Vixen sequence
NOTE:
 - SD LED will be ON whenever Vixen sends data to the Renard SS16.  The FE and OE LEDs should remain OFF.
- If this is correct, then your Renard SS16 has passed the diagnostics test.
 - If no LEDs were lit in step 19, then it seems that you are not getting any data from the computer.  Try the following:
- Make sure that your interconnect cable is built according to the Renard SS16 Controller wiki.
 - Replace U5
Verifying Diagnostic LEDs
- Turn OFF AC power
 - Turn ON AC power
- HB LED should light
- ZC LED should light
- SD LED should light
- FE LED should light
- OE LED should light
- Check for 5.0 VDC at U6 IC socket pin 1
- If incorrect, check the solder pads and/or go back to the Troubleshooting Power Problems Steps
 - Check for 5.0 VDC on the pins  (on underside of board) of resistor network RN1
 - If incorrect, check to make sure the shunt (jumper) is good
 - If any (but not all) of the LEDs in steps 6 thru 10 did not light, measure the DC voltage at the appropiate location on the IC socket for U6.  The voltage measured at each location should be approximately 3.0-3.5 VDC.
Troubleshooting SSR Circuitry Problems
Symptom(s):
- Bad triac
 - Bad opto
 - Bad/missed solder joints
- Turn OFF AC power
 - Are any of the triac gate resistors (R26-R41) burnt/blown/damaged?
 - Are all channels 9-16 bad?
- Check the right side fuse
 - Is the problem channel (channels 9 thru 16) controlled by U7?
- Go to step 22
 - Is the problem channel (channels 1 thru 8) controlled by U6?
- If not, then what are you doing at this step. Start over.
 - Turn ON AC power
 - Test lights should be OFF
- If the test lights are ON, go to step 37
- Turn OFF AC power
 - Install PIC chip U6
 - Turn OFF AC power
 - Turn OFF AC power
 - Turn ON AC power
- Bad triac
- It should be 5 VDC
 - Remove PIC chip U7
 - Turn ON AC power
- Turn OFF AC power
 - Install PIC chip U7
 - Turn OFF AC power
- Return to step 23 and repeat tests with the new opto
 - Turn OFF AC power
 - Turn ON AC power
- Bad triac
 - Turn OFF AC power
 - Remove the opto (M1-M16) controlling the bad channel
 - Turn ON AC power
 - Is the test light still ON?
