Serial, RS232
Voltages
| Level | Transmitter capable (V) | Receiver capable (V) |
| Space state (0) | +5 Vdc up to +15 Vdc | +3 Vdc up to +25 Vdc |
| Mark state (1) | -5 Vdc up to -15 Vdc | -3 Vdc up to -25 Vdc |
| Undefined | - | -3Vdc up to +3Vdc |
Pinouts
| View - looking into Male connector | View - looking into Female connector |
| Pin No. | Name | Dir | Notes/Description |
| 1 | DCD | IN | Data Carrier Detect. Raised by DCE when modem synchronized. |
| 2 | RD | IN | Receive Data (a.k.a RxD, Rx). Arriving data from DCE. |
| 3 | TD | OUT | Transmit Data (a.k.a TxD, Tx). Sending data from DTE. |
| 4 | DTR | OUT | Data Terminal Ready. Raised by DTE when powered on. In auto-answer mode raised only when RI arrives from DCE. |
| 5 | SGND | - | Ground |
| 6 | DSR | IN | Data Set Ready. Raised by DCE to indicate ready. |
| 7 | RTS | OUT | Request To Send. Raised by DTE when it wishes to send. Expects CTS from DCE. |
| 8 | CTS | IN | Clear To Send. Raised by DCE in response to RTS from DTE. |
| 9 | RI | IN | Ring Indicator. Set when incoming ring detected - used for auto-answer application. DTE raised DTR to answer. |
Achievable Distances
The maximum distance that RS-232 can go varies depending on Baud Rate and also the capacitance of the wire itself. Texas Instruments states that RS-232 maximum cable length is 50 feet, or the cable length equal to a capacitance of 2500 pF. Depending on the cable such as Category 5 Twisted pair the maximum achievable distance at 19200 is 157 feet.
Here is a chart showing theoretical limits as various data rates for RS-232 cable length according to Texas Instruments.
| Baud rate | Maximum cable length (ft) |
| 19200 | 50 |
| 9600 | 500 |
| 4800 | 1000 |
| 2400 | 3000 |
Advantages
RS-232 is without doubt the best known interface, because this serial interface is implemented on almost all computers available today.
Disadvantages
One of the main problems with RS-232 is the lack of immunity for noise on the signal lines.
However RS-232 suffers from three main problems:
- 1) it requires multiple ground points and can create potential ground loops.
 - 2) it picks up noise easily and
 - 3) it allows only short communication distances.
In order to overcome some of these issues RS-422 or RS-485 is the preferred choice.
Interfacing to Microcontrollers
In order for RS232 to communicate with a Microcontroller such as a Pic16f88 or Atmel, level conversion must first be done because of the voltage levels on TTL is 5 Vdc max and normal RS232 far exceeds voltage limitations and damage will occur.
Devices such as a MAX232 will make the necessary voltage conversion possible for communication to and from TTL devices.
