Serial, RS232
Voltages
| Level | Transmitter capable (V)  | Receiver capable (V)  |
| Space state (0) | +5 ... +15 | +3 ... +25 |
| Mark state (1) | -5 ... -15 | -3 ... -25 |
| Undefined | - | -3 ... +3 |
Pinouts
| Pin No. | Name | Dir | Notes/Description | ||||
| 1 | DCD | IN | Data Carrier Detect. Raised by DCE when modem synchronized. | ||||
| 2 | RD | IN | Receive Data (a.k.a RxD, Rx). Arriving data from DCE. | ||||
| 3 | TD | OUT | Transmit Data (a.k.a TxD, Tx). Sending data from DTE. | ||||
| 4 | DTR | OUT | Data Terminal Ready. Raised by DTE when powered on. In auto-answer mode raised only when RI arrives from DCE. | ||||
| 5 | SGND | - | Ground | ||||
| 6 | DSR | IN | Data Set Ready. Raised by DCE to indicate ready. | ||||
| 7 | RTS | OUT | Request To Send. Raised by DTE when it wishes to send. Expects CTS from DCE. | ||||
| 8 | CTS | IN | Clear To Send. Raised by DCE in response to RTS from DTE. | ||||
| 9 | RI | IN | Ring Indicator. Set when incoming ring detected - used for auto-answer application. DTE raised DTR to answer. |
Achievable distances
The maximum distance that RS323 can go varies depending on Bit Rate and also the capacitance of the wire itself. Texas Instruments states that RS 232 maximum cable length is 50 feet, or the cable length equal to a capacitance of 2500 pF. Depending on the cable such as Category 5 Twisted pair the maximum achievable distance at 19200 is 157 feet.
here is a quick chart showing theoretical limits as various data rates for RS232 cable length according to Texas Instruments
| Baud rate | Maximum cable length (ft) |
| 19200 | 50 |
| 9600 | 500 |
| 4800 | 1000 |
| 2400 | 3000 |
