Vixen Add-ins
Color Organ
Is there any information for an add-in to provide a color organ response to a musical selection, similar to the waveform add-in except it separates the audio in to 3 or more individual channels based on frequency. If anyone or a group are interested in working on this, here is the place to document it
Frequency Spectrum
- The Frequency Spectrum add-in splits the audio soundtrack of the sequence into frequency bands.
 - These bands are linked to channels in the sequence.
 - The add-in examines the soundtrack.
 - If the amplitude of a frequency band reaches the set point then the cells of the linked channel where this occurs are set to 100% intensity. Cells that were not set by the add-in retain their original value.
 - The Scale is adjusted to alter the threshold at which the cells are set to 100% intensity.
Components of Frequency Spectrum Add-in
Frequency Bands
The audio is split into 31 bands ranging from 20Hz up to 20kHz. When you play the sound track a bar graph of the amplitude of that frequency is displayed in the black rectangle. The lower portion of the bar graph is Green, with the mid an upper sections appearing as Yellow and Red respectively. The height of the bar graph is affected by the Scale setting.
Channel Indicators
The channels in the sequence are shown as a row of squares below the frequency band. If there are more channels than can be displayed in the window then there will be scroll arrows visible to indicate that more channels are available. Click on the arrow to display these channels. Hovering the mouse pointer over a channel indicator will display the channel name.
Auto Mapping channels
The channels can be automatically mapped. Click on the Auto Map button to display the auto map options screen. With auto mapping you need to have 31 consecutive channels available if all frequency bands are used.
The first channel in the sequence and the first frequency band are displayed when the auto map window is initially displayed.
- From the Start channel drop down list select the first channel to be used by the add-in.
 - From the Start band drop down list select the first frequency band that you want to utilize. Any frequency bands below the selected start band will be ignored.
 - Click on the OK button to map the channels. The frequency bands will then be individually mapped onto consecutive channels according to the choices you have made.
Manually Mapping Channels
Manually mapping the channels allows you to be more selective and creative with the channel mapping when compared to auto mapping.
In the example shown above you can see a frequency band linked to a single channel, a group of frequencies linked to a single channel and a single frequency band linked to multiple channels. More complex linkages can be achieved than what has been shown.
- To link a frequency band to a channel, position the cursor over the black area of the frequency band and drag the cursor over to the desired channel. When the mouse button is released the link will be created. Or in the reverse direction by dragging from the channel indicator to the frequency band.
 - To break a link drag the White marker (at the top of the link connecting line) into any white space outside of the black area. Or by dragging the Black marker (at the bottom of the link connecting line) into any white space outside of the channel indicators.
 - To move a link simply drag a marker to the desired location. When you move a link from one frequency band into another band already containing a link, then the link you are moving will replace that link.
 - To link a frequency band to multiple channels simply drag from the black area of the desired frequency band to as many channels as required.
 - To link a channel to multiple frequency bands requires an intermediate step. Once the first link to a channel is made, the add-in will not let you directly link additional frequency bands to that same channel. You must first create links to separate channels.
Then drag the links to the desired channel.
