24 Channel Renard with SSR Assembly Instructions
Layout
COOP PCB V2.5
Co-Op Board 3.0 Assembly Instructions
Currently in-process!
Design Notes for v 3.0 Co-Op Board
No notes yet!
PCB 1 Ren24v3 Renard 24-Port PCB Board Specific Parts: 571-7969494 1 595-SN75176BP 2 511-L7805CV 1 821-DB102G 1 '''SUB PART 512-DF01M''' 532-7136DG 1 271-27K-RC 3 271-1K-RC 4 271-120-RC 1 625-1N4001-E3 1 78-1N5239B 2 838-3FD-320 1 782-H11AA1 1 520-TCF1843-X 1 140-HTRL25V1000-RC 1 140-HTRL25V10-RC 1 534-3517 4 504-GMA-15 2 Parts from the Common Parts List: 511-BTA08-400B 24 (or 511-BTA04-700T more sensitive triac for LED's) 859-MOC3023 24 579-PIC16F688-I/P 3 604-WP63ID 2 604-WP1503GD 1 271-180-RC 24 271-680-RC 27 581-SA105E104MAR 5 571-41032390 1 571-3828115 4 571-1-390261-2 2 571-1-390261-3 3 571-3902611 24 (Optional 6 Pin Socket for Optocoupler - Recommended) 571-5564161 2 Common Parts Description: ST Microelectronics BTA08 Triac Driver (24 needed) MOC 3023 Optocoupler (24 needed) Microchip PIC 16F1688 (3 needed) Red T1 3/4 LED (2 needed) Green T1 3/4 LED (1 needed) 180ohm 1/4 watt resistor (24 needed) 680ohm 1/4 watt resistor (24 needed) .10 uF Ceramic Capacitor (5 needed) .100 three pin header (4 needed) Part specified is a 40 pin, cut off size that is needed. .100 Shunt (4 needed) You may also "steal" these off of old computer parts. 6 pin DIP socket (optional - 24 needed) 8 pin DIP socket (2 needed) 14 pin DIP socket (3 needed) RJ45 Sockets (2 needed) orientation doesn't matter. Specified part is same as the Ren64 Parts changed for board 3.0 PART OPTION #1 - Using Screw Down Terminals 571-2828376 4 6 Position Screw Down Terminal 651-1725041 4 3 Position Double Stacked Terminal PART OPTION #2 - Using Spade Terminals 534-1287 48 Spade Terminals
- NOTE UPDATED 10/06 - I put the wrong transformer part # Old part is 838-3FD-310 please see here if you purchased any.
01/20/2007 Initial Design 03/20/2007 Revision 2 submitted to test manufacturing. 07/15/2007 Changed RJ45 to comply with current Renard standards. 07/15/2007 Added additional holes for a larger transformer. 07/15/2007 Added transformer voltage selection jumpers, will allow for 120/240v operation for our friends down under. 07/15/2007 Changed fuse size to 5x20mm fuse from AG3 fuse. 07/16/2007 Added option for DIP or SMT MOC2032 optos. 08/20/2007 Version 2.5 submitted to test manufacturing. 10/01/2007 Making small adjustments based on user feedback to ease setup of board. No major changes made. 01/14/2008 Corrected RS485 pins 4/5 to match Ren16 and Ren64 01/14/2008 Minor silkscreen corrections. 01/14/2008 Increase the size of the board to add a neutral buss onto the board. 01/14/2008 Added support for either spade terminals or screw down terminals.
Errata for Rev 1 PCB -
1) Onboard regulator not functioning properly: needed addition of 1000uF capacator. (corrected in rev 2.0 board) 2) Outputs are out of order. (corrected in rev 2.0 board) 3) Triacs are located to close together. (corrected in rev 2.0 board)
Errata for Rev 2 PCB -
1) RS485 traces swapped from the Ren16/Ren64 pin config. (To be corrected in Rev 3.0 Board) 2) Silkscreen needs to have some clarification done for part orientation.
Planned Errata for Rev 3.0 PCB - (Board not yet in production)
2) 24v/36v input voltage support. (This requires more of locating compatable parts)
Design Notes for v 2.5 Co-Op Board
The parts list has a 100uF cap, ignore it - as its not needed (Deleted from BOM) There is a 1uF on the board, also not needed.
The 7805 (flat side) goes to the top of the board.
The heatsink for the 7805 should be trimmmed at the bottom to allow for proper fit.
The fuse clips are two tight for the board - now sure how this happened - I need to look into this more - as this is the part that I ordered last year and it fits fine.
There are two resistors that are close to the output blocks, when installing them, leave them up a bit so they can be pushed back a little bit.
PC to Renard24 Cable
The FKostyun Renard24 board has on-board power supply circuitry and on-board zero-crossing circuitry, so all that it needs on the RJ45 cable are data signals and ground. If you are using RS232 input and connecting it directly to the PC serial port, the following cable pinouts will work:
Version 3.0 Board:
PC DB9 Pin 3 to RJ45-pin 4 PC DB9 Pin 5 to RJ45-pins 1,2,4 (pins 1 and 4 are required, pin 2 is optional).
Version 2.5.0 Board:
PC DB9 Pin 3 to RJ45-pin 5 PC DB9 Pin 5 to RJ45-pins 1,2,4 (pins 1 and 4 are required, pin 2 is optional).
NOTE: The 2.5.0 cable will not work with the Renard16, Renard64 or Ren-C boards because pins 4 and 5 on the version 2.5.0 Renard24 are reversed from those other boards.
