10' Megatree
Materials and Tools
 - T-post
 - 12½ feet of ½ inch polyethylene drip irrigation distribution tubing
 - Polyethylene drip irrigation coupling
 - Sharpie® permanent marker
- = You may want to put something such as a star on the top of the Megatree. If so, choose a coupling that slip fits onto the 1 inch PVC pipe on one end, and is threaded on the other end for attaching the decoration.
Construction
Hook assembly with wires attached
Tie the light strings to the EMT pipe with Velcro® strips in about three places, to contain the tangle of wires.
Installation
Place the EMT pipe (with light strings attached) over the T-post; the Megatree should remain comfortably self-standing.
Sorting out each of the light strings, run both the plug and receptacle end of the light string under the irrigation tubing, proceeding in a clockwise direction. Place weights on the irrigation tubing at intervals as you go to secure it in place. Surprisingly little securing is needed for the strings to stay in place for the season, usually about 4 weights should do it.
Storage
Being careful not to step on light bulbs on the ground, tie the light strings to the EMT pipe with Velcro® strips in about three places, to contain the tangle of wires.
Lift the EMT pipe with light strings attached off of the T-post, remove the decoration from the top of the display if applicable/desired, and set aside.
Store your Megatree, T-post and irrigation tubing ring as you have planned. BTW, if you followed the instructions above you now have a "spare" 1 inch PVC pipe with coupling/cap on the end. If you're looking for a good Megatree storage idea, check out my suggestion here. That's where you will use the spare PVC pipe.
