10' Megatree
Materials and Tools
 - T-post
 - 12½ feet of ½ inch polyethylene drip irrigation distribution tubing
 - Polyethylene drip irrigation coupling
 - Sharpie® permanent marker
- = You may want to put something such as a star on the top of the Megatree. If so, choose a coupling that slip fits onto the 1 inch PVC pipe on one end, and is threaded on the other end for attaching the decoration.
Construction
Installing completed hook assembly into EMT pipe
Hook assembly with wires attached
Installation
Place the EMT pipe (with light strings attached) over the T-post; the Megatree should remain comfortably self-standing. Find the plastic hook that you marked with the Sharpie® and orient it in the direction (i.e., North) you planned. Remove the Velcro® straps.
Sorting out each of the light strings, run both the plug and receptacle end of the light string under the irrigation tubing, proceeding in a clockwise direction. Place weights on the irrigation tubing at intervals to secure it in place. Surprisingly little securing is needed for the strings to stay in place for the season, usually about 4 weights should do it.
Storage
Now your season has ended, and you're ready to store your Megatree. Unplug each light strand and insert the plug into its receptacle. This helps reduce tangling of the strands. Pull the strings out from under the irrigation tubing and cluster around the EMT pipe.
Being careful not to step on light bulbs on the ground, tie the light strings to the EMT pipe with Velcro® strips in about three places, to contain the tangle of wires.
Lift the EMT pipe with light strings attached off of the T-post, remove the decoration from the top of the display if applicable/desired, and set aside.
Store your Megatree, T-post and irrigation tubing ring as you have planned. BTW, if you followed the instructions above you now have a "spare" 1 inch PVC pipe with coupling/cap on the end. If you're looking for a good Megatree storage idea, check out my suggestion here. That's where you will use the spare PVC pipe.
