Electronics Hardware
Links
SSR Direct Attach
Kit74
Hill320
Olsen 595/Grinch
 - Documentation: Olsen 595
Firegod
 - Documentation: Firegod
This is a modular system that supports 32 to 128 channels per serial port, in increments of 32 channels, with 100 levels of dimming (using pulse width modulation - PWM). It consists of a host controller module and one to four field modules. The SSRs are not included on these boards, and must be provided separately. The interface to this system is RS-232. This system is no longer available on a coop basis. You would need to etch your own of find someone whp has one for sale. This board is intermediate in complexity to build.
Renard
Lynx
- Controlled through: DMX
Helix
 - Documentation: Helix
Fox Cub
Pixel Controllers
 - Documentation: Controllers
Other Controllers & Light Specific Driver Boards (High Power LEDs, Signs, Servos, etc.)
The RobG 10W RGB LED Driver Board
This board implements a constant current driver for the commonly found 10W RGB LED modules. The board supports remote power injection and is very simple to interface to most DIYC controllers. (non-pixel types)
LedTriks
Triks-C
LEDTRIKS LED PANELS
PIX-C
 - Documentation: PIX-C
JEC Pixel Displays
rgbLED
Color Stick
 - Documentation: Color Stick
- Documentation: Super Strip
RS485 Splitter
Power Distribution Boards
- Documentation: Power_Distribution_Boards test text
Boards to help you split power from one to many connections.
With the introduction of iOT (Internet of Things) technology, the ability to have wireless wifi devices has now reached a point of easy use and very low cost. This section covers gear that utilizes these technologies.
E1.31 Bridges
6 Port e1.31 Bridge by DIYLEDEXPRESS
 - It can be purchased here
3 & 4 Port E1.31 Bridge/SPI Controller by HolidayCoro
The following controllers have dedicated, built-in RS485 interfaces in-addition to 16 SPI outputs:
3 Ports:  AlphaPix 16
4 Port e1.31 Bridge by RPM
FM Transmitters & Antennas
DMX Boards, both converters and light controllers
This section is under construction, please consider all links broken below
			Renard SS 8
			Renard SS 16
			Renard SS 24
			RPM USB to DMX Adapter
			RPM DMX4 SSR
			RPM DMX16 SSR
			RPM DMX8 DC SSR
			RPM DMX16 DC SSR
Digital Input/Output Cards
