Electronics Hardware
Links
Power Distribution Boards- Boards to help you split power from one to many connections.
SSR Direct Attach
Kit74
Hill320
Olsen 595/Grinch
 - Documentation: Olsen 595
Firegod
 - Documentation: Firegod
This is a modular system that supports 32 to 128 channels per serial port, in increments of 32 channels, with 100 levels of dimming (using pulse width modulation - PWM). It consists of a host controller module and one to four field modules. The SSRs are not included on these boards, and must be provided separately. The interface to this system is RS-232. This system is no longer available on a coop basis. You would need to etch your own of find someone whp has one for sale. This board is intermediate in complexity to build.
Renard
Lynx
- Controlled through: DMX
Helix
 - Documentation: Helix
Fox Cub
Pixel Controllers
 - Documentation: Controllers
Other Controllers & Light Specific Driver Boards (High Power LEDs, Signs, Servos, etc.)
The RobG 10W RGB LED Driver Board
This board implements a constant current driver for the commonly found 10W RGB LED modules. The board supports remote power injection and is very simple to interface to most DIYC controllers. (non-pixel types)
LedTriks
Triks-C
LEDTRIKS LED PANELS
PIX-C
 - Documentation: PIX-C
JEC Pixel Displays
rgbLED
Color Stick
 - Documentation: Color Stick
- Documentation: Super Strip
RS485 Splitter
- Documentation: Power_Distribution_Boards
With the introduction of iOT (Internet of Things) technology, the ability to have wireless wifi devices has now reached a point of easy use and very low cost. This section covers gear that utilizes these technologies.
E1.31 Bridges
6 Port e1.31 Bridge by DIYLEDEXPRESS
 - It can be purchased here
3 & 4 Port E1.31 Bridge/SPI Controller by HolidayCoro
The following controllers have dedicated, built-in RS485 interfaces in-addition to 16 SPI outputs:
3 Ports:  AlphaPix 16
4 Port e1.31 Bridge by RPM
FM Transmitters & Antennas
DMX Boards, both converters and light controllers
This section is under construction, please consider all links broken below
			Renard SS 8
			Renard SS 16
			Renard SS 24
			RPM USB to DMX Adapter
			RPM DMX4 SSR
			RPM DMX16 SSR
			RPM DMX8 DC SSR
			RPM DMX16 DC SSR
Digital Input/Output Cards
