- Pixel Controllers
 - Dumb RGB Controllers.
 - E1.31 (DMX over Ethernet)
When choosing a Pixel controller it is important that you confirm that your selection is compatible with you system design.  Critical properties to consider include are:
 - Advanced Features
 - Etc.
PIXEL CONTROLLERS
Open Lighting Architecture
OLA can be used on a Raspberry Pi, Beagle Bone Black or other single board computers with SPI. It can receive E1.31 (and many other protocols) and use the data to drive SPI pixels. See https://wiki.openlighting.org/index.php/OLA_LED_Pixels for more information. The maximum pixel count is determined by the hardware and the pixel clock speed. Demo Video.
HolidayCoro
Default IP Address is 192.168.0.50 (configurable via LCD interface or webpage) or can be configured for DHCP.| Model | Max Pixels | DMX Universes | Pixels Supported | Output Connectors | String Outputs | Image | Link | Price | Manual/Videos | Note |
| AlphaPix 4 V2 | 2,720 | 16 UniCast (E1.31 & Artnet) | WS2811,WS2812,WS801,WS2803 TM1804,TM1803,TM1812,SM16715 TLS3001,TLS3002,CY3005 LPD6803,D705,LPD1101  |
4 Fused Outputs Screw Terminals  |
4 Outputs 680 Pixels Per Output  |
Product Link | Assembled $99.99 | Demo Video Setup Videos  |
Includes one dedicated RS-485/DMX output (does not use a pixel output), 28A per Controller/7.5A per Output, LCD Display for Configuration and Testing, WEB Interface for configuration and monitoring, Adapter mounting plates for CG1500 enclosure available, built-in voltage and temperature sensor allow remote controller monitoring along with the built-in fan controller for cooling the enclosure | |
| AlphaPix 16 V2 | 5,440 | 32 UniCast (E1.31 & Artnet) | WS2811,WS2812,WS801,WS2803 TM1804,TM1803,TM1812,SM16715 TLS3001,TLS3002,CY3005 LPD6803,D705,LPD1101  |
16 Fused Outputs Screw Terminals  |
16 Outputs 340 Pixels Per Output  |
Product Link | Assembled $199.99 | Demo Video Setup Videos  |
Includes three dedicated RS-485/DMX outputs (does not use a pixel output), 30A per Bank, 2 Banks per Controller (60A Total)/5A per Output (80A at 20% Duty Cycle), LCD Display for Configuration and Testing, WEB Interface for configuration and monitoring, Adapter mounting plates for CG1500 enclosure available, built-in voltage and temperature sensor allow remote controller monitoring along with the built-in fan controller for cooling the enclosure |
Advatek Lighting Pty Ltd
(Australia Based run by DIYC user Unknown (Devo))
| PixLite 4 | 2,720 | 16 UniCast 16 MultiCast  |
WS2811,WS2812,WS801,WS2803 TM1804,TM1803,TM1812,SM16715 TLS3001,TLS3002,CY3005 LPD6803,D705,LPD1101 USC6909,UCS6912,SM16716,MBI6020  |
MFG Product Link  US Re-Seller Link  |
Assembled $114.95 | Manual  |
Includes one dedicated RS-485/DMX output, 28A per Controller/7A per Output, Gamma Correction, Temp & Power Monitor | |
| PixLite 16 | 5,440 | 32 UniCast 32 MultiCast  |
Assembled $199.95 | Manual  |
Includes four dedicated RS-485/DMX outputs (does not use a pixel output), 30A per Bank, 2 Banks per Controller (60A Total)/4A per Output, Gamma Correction, Temp & Power Monitor |
SanDevices
| E6804-4 | 2040 | 7Multicast / 12Unicast | GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others | 4 Fused (1x4 Electrical, 4x1 Logical) | 6120 | Up to 12 | link | Assembled/Tested: $99, Full Kit: Price $69 Presale | Owner's Assembly | Size is 2.5" x 4", mounting holes on 2"x3" centers, compatible with CG series enclosures. Announcement | |
PixelController.com (Falcon)
Default IP Address is 192.168.1.50. Can be configured via OLED interface or webpage. Supports DHCP (Dynamic Host Configuration Protocol).| Model | Max Pixels | DMX Universes | Pixels Supported | Output Connectors | String Outputs | Image | Link | Price | Note |
| F16V2 | 10,880 | 64 Multicast/Unicast (E1.31) | WS2811,WS2812,WS801,WS2803 TM1804,TM1803,TM1812 GECE TLS3001,TLS3002,CY3005 LPD6803,D705,LPD1101  |
16/32 Fused Outputs Screw Terminals  |
16/32 Outputs 680 Pixels Per Output (340 when in 32 port mode)  |
Store | Assembled $200.00 | 5V-32V DC, Every port can be a different type. Expandable to 32 ports, soon to be 48 ports. Virtual string support. Includes four dedicated RS-485/DMX outputs, 30A per Bank, 2 Banks per Controller (60A Total)/5A per Output, OLED Display for Configuration and Testing, Webpage Interface, Mounting plate for CG1500 enclosure available. Voltage and temperature sensors. OLED E131 diagnostic tools. 4 - Renard (Speed and stop bits configurable), DMX and Pixelnet Outputs. |
Joshua 1 Systems (J1SYS)
Stellascapes
| E16-II Pro | 672 | 6Unicast | Stella-black | 16 Fused (? Electrical, ? Logical) | 2016 | ? | link | Assembled Board: $?? | With power supply and Neutrik XLR, power and ethernet chasis connectors | ||
| E2 | 170 | 1Unicast | Stella-black | 2 ? | 512 | ? | link | Assembled Board: $?? | With power supply,operates on low voltage DC (12-48V) |
DMX512 / ESTA 1.11 (RS485) to SPI
HolidayCoro
| Model | Max Pixels | DMX Channels | Pixels Supported | Output Connectors | Image | Link | Price | Note |
| EasyPix V2 | 170 | 512 | WS2811,WS2812,WS801,WS2803  TM1804,TM1803,TM1812,SM16715 TLS3001,TLS3002,CY3005 LPD6803  |
1 Fused Output Screw Terminals  |
Product Link | $39.99 | Null pixels, Reverse order,Push button setting with back-lit LCD screen, built-in sequences, replaceable output chip |
| DCG-P2 | 170/680* | 1DMX/*4HyperDMX | LPD6803, WS2801, WS2811, TM180x, TLS3001 | 2 Unfused (1x2 Electrical, 1x2 Logical) | 512DMX/*2048HyperDMX | 1 | link | Assembled Board: $53 | 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels | ||
| uDCG-P2 | 170/680* | 1DMX/*4HyperDMX | LPD6803, WS2801, WS2811, TM180x, TLS3001 | 2 Unfused (1x2 Electrical, 1x2 Logical) | 512DMX/*2048HyperDMX | 1 | link | Assembled Board: $42, Assembled Board w/Case: $48 | 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels |
Ray Wu
(China Based)
DIYB
Electron Design
(Israel based)
AVD
ACL
Onumen
RPM
Stellascapes
- T3: DMX512 - SPI Bridge
SD Memory Card to SPI
Ray Wu
(China Based)
Light-O-Rama (LOR) to SPI
Light-O-Rama (LOR)
(USA Based)
PIXEL Extenders
- ECG-PPX
E1.31 Bridges and DMX Dongles
DIYLEDEXPRESS
RPM
USB to DMX512 Output
 - Enttec Open DMX USB
 - Enttec DMX USB Pro
 - RPM DIY USB to DMX Adaptor
 - RJ's LYNX DMX DONGLE
FTDI drivers for dongles:
- FTDI VCP Drivers
| HolidayCoro | #27 / Water Resistant / Boxed / Pigtails / 9 Test Sequences | Yes | 6V - 24V | 3 | 2A | 6A per 3 Ch | DMX | $9.49 | $3.16 |
| Audiolight Intl | HD-714 US China | Yes | 12V - 24V | 3 | 2A | 6A | DMX | $8.95 | $2.98 |
| Audiolight Intl | HD-712 US China | Yes | 12V - 24V | 27 | 1A | 15A | DMX | $44.21 | $1.64 |
| Leynew | LN-DMXMODEL-3CH-LV12 US China | Yes | 12V | 3 | 2A | 6A | DMX | $7.49 | $2.49 |
| DIYLEDExpress | Ren24DC | Built or Kit | 5,7-24vdc | 24 | 4A | 30A x 2 | RS232/485, DMX | $72.10 | $3 |
Different Styles of Pixels
Waterproofing Pixels
Null Pixels
