RenardESP
The board to make your RENARD controller run from a wifi connection
The RenardESP is a WiFi adapter for Renard Christmas light dimmers. Based off the ESP8266 chipset, this adapter will turn your Renard dimmer into a full fledged e1.31 sACN device. The firmware includes a web server that allows the end user to adjust the various settings.
If you need to brush up on e1.31 sACN, you can read the wiki entry here: e1.31 sACN
Safety Features
Neons are used instead of an incandescent bulbs due to the fact that a neon bulb is very long lived and is much 'tougher' then an incandescent since there is no filament to break.
4.  The 2 ounce copper AC traces are mirrored on both sides of the board.  This allows for greater current carrying capacity. (8 amps)
The board has two points to mount it to the TA-200 enclosure. Great pains were taken to make sure that the screws that come with the enclosure can be used once they have been cut down to a proper length.  You can use the screws that come with the enclosure provided you cut them off.  The correct length of the cut off shaft BELOW the head is 5/8".
The screws that come with the enclosure are nice in that they have both a hex head and a screw driver slot for installation/removal.  (Plus they are free with the enclosure!)
The Schematic can be viewed by clicking on this link:
SSRneon-G2-LED Schematic
Order your own boards
Home Etch
If you want to home etch an SSR, please go to the wiki entry for the SSRneon-G2 which is a home etch friendly design and has design files specifically built for home etching.
(ref: SSRneon-G2 wiki entry )
Fuse Rating
BOM for 120VAC Operation:
2      606-A9A            Neon Lamp 65VAC .7mA NE-2E marked NE1, NE2  (See the note below for an alternative source)
1      571-5556416-1      Modular Jacks 8 PCB TOP ENTRY marked J1
4      511-BTA04-700T     Triacs 4 Amp 700 Volt marked U1, U2, U3, and U4
            OR
       511-BTA06-600S     Triacs 6 Amp 600 Volt marked U1, U2, U3, and U4
1      534-3527C          Fuse Cover
5      604-WP7104IT       LED Standard HI EFF RED TRANS marked LED1, LED2, LED3, LED4, LED5
1      660-CF1/4C681J     1/4Watt Axial Carbon Film Resistors 680ohms 5% marked R9
4      660-CF1/4C221J     1/4Watt Axial Carbon Film Resistors 220ohms 5% marked R1, R2, R3, R4
2      660-CF1/4C104J     1/4Watt Axial Carbon Film Resistors 100Kohms 5% marked R10, R11
4      859-MOC3023        Optocomponents Optocoupler marked IC1, IC2, IC3 and IC4
4      571-1-390261-1     IC Sockets 6P ECONOMY TIN marked IC1, IC2, IC3, IC4
5      571-2828372        Terminal Blocks 5.08MM PCB MOUNT 2P marked TB1, TB2, TB3, TB4, TB5
1      504-GMC-8          5mm x 20mm Medium Time Delay Fuses 125VAC 8A Med Time Delay
See above for TA-200 sources.
1                         Male Plug Power Cord, Rated for 10A Minimum
Jameco, www.jameco.com, sells the NE-2E neon bulb for about half of mousers price.  Jameco Part Number:  210260
Leaving out the LED Channel Indicators
I don't want the LED Indicators !
How to use LEDs of many colors for the Channel Indicators
Red LEDs have a typical forward voltage (Vf) of 2.0 volts. However, other colors, like green, have a Vf of 3.x volts. Therefore, if you use a LED with a Vf in this range, you should replace the 220 ohm resistor connected to that LED with a 180 ohm resistor.
The basic equation is:
V(supply):  Supply voltage, in our case 5V
Vf(opto):  Forward voltage of the opto emitter, 1.5V max, 1.15 typ
Vf(LED):  Forward voltage of the LED, for the LEDs I use it is 2.0V
Vol:  Low voltage output level, For the purposes of this calculation, a value of 0.33V max, 0.18V typical was used.
If you are concerned about the current draw then you can increase the value of R based on the typical values (i.e. to either 270 or 300).  However, there is a concern that with the temperature extremes these devices are used in, this would push them closer to the max values and cause erratic behavior.
Here is a picture of a completed SSRneon-G2:  (The fuse cover has been removed)
Wiring The SSRneon
 Controller Output Pinout
