Revision as of 19:51, 6 February 2015 by Dmoore (talk | contribs) (HolidayCoro)
  • Pixel Controllers
  • Dumb RGB Controllers.
  • Renard (using either RS232-serial or RS485)
  • E1.31 (DMX over Ethernet)
  • DMX A traditional stage lighting protocol
  • Programs stored on SD memory cards
  • Lightorama LOR compatable gear
  • Communications Protocol (E1.31, Renard, DMX, LOR, Etc.)
  • Pixel Voltage (5VDC vs 12VDC)
  • Pixel Type (WS2801, WS2811, GECE, LOR, Etc.)
  • Number of Pixels to be Controlled
  • Number of Connectors and Number of Strings that can be Physically Connected
  • Advanced Features
    • Grouping (ability to treat multiple Pixels as one)
    • RGB Ordering (ability to correct the physical RGB order to match the software sequence order)
    • ZigZag (Ability to treat physical strings as multiple logical strings)
    • Reverse order (ability to reorder the channels on a string so the most distant one is the first channel)
    • Etc.
PIXEL CONTROLLERS
Renard PX1 Pixel Controller
HolidayCoro
Model Max Pixels DMX Universes Pixels Supported Output Connectors String Outputs Image Link Price Manual/Videos Note
AlphaPix 4 2,720 16 UniCast
16 MultiCast
WS2811,WS2812,WS801,WS2803
TM1804,TM1803,TM1812,SM16715
TLS3001,TLS3002,CY3005
LPD6803,D705,LPD1101
4 Fused Outputs
Screw Terminals
4 Outputs
680 Pixels Per Output
Product Link Assembled $99.99 Coming Soon Includes one dedicated RS-485/DMX output (does not use a pixel output), 28A per Controller/7.5A per Output, LCD Interface
AlphaPix 16 5,440 32 UniCast
32 MultiCast
16 Fused Outputs
Screw Terminals
16 Outputs
340 Pixels Per Output
Product Link Assembled $174.99 Coming Soon Includes three dedicated RS-485/DMX outputs (does not use a pixel output), 24A per Bank, 2 Banks per Controller (48A Total)/3A per Output, LCD Interface
Advatek Lighting Pty Ltd
PixLite 4 2,720 16 UniCast
16 MultiCast
USC6909,UCS6912,SM16716,MBI6020
4 Fused Outputs
Screw Terminals
4 Outputs
Product Link Assembled $129.99 General Setup Video
LOR S3 Setup Video
Manual
Includes one dedicated RS-485/DMX output, 28A per Controller/7A per Output, Gamma Correction, Temp & Power Monitor
PixLite 16 5,440 32 UniCast
32 MultiCast
16 Fused Outputs
Screw Terminals
16 Outputs
Product Link Assembled $219.99 General Setup Video
LOR S3 Setup Video
Manual
Includes four dedicated RS-485/DMX outputs (does not use a pixel output), 30A per Bank, 2 Banks per Controller (60A Total)/4A per Output, Gamma Correction, Temp & Power Monitor
SanDevices
E68x Configuration Guide
Firmware Updates
Model Max Pixels DMX Universes Pixels Supported Output Connectors Max Channels DMX Universes per Output Image Link Price Manual Note
E6804-4 2040 7Multicast / 12Unicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 4 Fused (1x4 Electrical, 4x1 Logical) 6120 Up to 12 link Assembled/Tested: $99, Full Kit: Price $69 Presale Owner's Assembly Size is 2.5" x 4", mounting holes on 2"x3" centers, compatible with CG series enclosures. Announcement
PS-1 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link Turnkey System: $399 Owner's Assembled E682 with power supply in an Enclosure
E682-12 2040 6Multicast / 12Unicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 6120 Up to 12 link Assembled/Tested: $180, Full Kit: Price $109 Owner's Assembly To be released shortly
E682-6 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link Assembled/Tested: $180, Full Kit: Price $109 Owner's Assembly Original E682, Before Firmware Upgrade
E681-12 2040 6Multicast / 12Unicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 6120 Up to 12 link No Longer Available Owner's Assembly Firmware To be released shortly, requires UP1 upgrade
E681-6 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link No Longer Available Owner's Assembly Original E681, with Firmware Upgrade and UP1 upgrade
E681-4 680 4Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 2040 Up to 4 link No Longer Available Owner's Assembly Original E681, without Firmware Upgrade and without UP1 upgrade
E680-12 2040 6Multicast / 12Unicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 6120 Up to 12 link Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function Owner's Assembly To be released shortly, requires UP1 upgrade
E680-6 1020 6Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 3060 Up to 6 link Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function Owner's Assembly Original E680, with Firmware Upgrade and UP1 upgrade
E680-4 680 4Multicast GECE, Native DMX, TM1804, 1903, WS2801, WS2811, TLS3001, CYT3005, LPD6803(+8bit), 8806, 9813, and others 16 Fused (2x8 Electrical, 4x4 Logical) 2040 Up to 4 link Partial Kit: $19 (PC Board + EEPROM) needs additional parts to function Owner's Assembly Original E680, without Firmware Upgrade and without UP1 upgrade
Joshua 1 Systems (J1SYS)
Tutorial Video
Setup Video
Unofficial Users Manual
ECG-P12R 2040 12Unicast LPD6803, WS2801, WS2811, TM180x, TLS3001 12 Fused (2x6 Electrical, 3x4 Logical) 6120 1 link Assembled Board: $175 Owner's Notes
ECG-PIXAD8 1360 8Unicast LPD6803, WS2801, WS2811, TM180x, TLS3001 8 Fused (2x4 Electrical, 2x4 Logical) 4080 1 link Assembled Board: $155 Owner's
ECG-P2 1360 8Unicast LPD6803, WS2801, WS2811, TM180x, TLS3001 2 Unfused (2x1 Electrical, 2x1 Logical) 4080 4 link Assembled Board: $68, Assembled Board w/case: $77 Owner's
Stellascapes
E16-II Green 672 6Unicast Stella-green 16 Fused (? Electrical, ? Logical) 2016 ? link Assembled Board: $1296 16 Character LCD Display for diagnostics and identification information.
E16-II Commercial 672 6Unicast Stella-black 16 Fused (? Electrical, ? Logical) 2016 ? link Assembled Board: $1995 With power supply and 16 400mm "tails" with waterproof screw up connectors
E16-II Pro 672 6Unicast Stella-black 16 Fused (? Electrical, ? Logical) 2016 ? link Assembled Board: $?? With power supply and Neutrik XLR, power and ethernet chasis connectors
E2 170 1Unicast Stella-black 2 ? 512 ? link Assembled Board: $?? With power supply,operates on low voltage DC (12-48V)
DMX512 to SPI
HolidayCoro
Model Max Pixels DMX Channels Pixels Supported Output Connectors Image Link Price Note
EasyPix 170 512 WS2811,WS2812,WS801,WS2803
LPD6803
1 Fused Output
Screw Terminals
Product Link $39.99 Null pixels, Reverse order,Push button setting with back-lit LCD screen, built-in sequences
DCG-P2 170/680* 1DMX/*4HyperDMX LPD6803, WS2801, WS2811, TM180x, TLS3001 2 Unfused (1x2 Electrical, 1x2 Logical) 512DMX/*2048HyperDMX 1 link Assembled Board: $53 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels
uDCG-P2 170/680* 1DMX/*4HyperDMX LPD6803, WS2801, WS2811, TM180x, TLS3001 2 Unfused (1x2 Electrical, 1x2 Logical) 512DMX/*2048HyperDMX 1 link Assembled Board: $42, Assembled Board w/Case: $48 2 Pixel Outputs share 1 DMX or 4 HyperDmx input channels
Ray Wu
(China Based)
DIYB
Electron Design
(Israel based)
AVD
ACL Wiki
ACL Thread
ACL
Onumen
RPM
Stellascapes
  • T3: DMX512 - SPI Bridge
SD Memory Card to SPI
Ray Wu
(China Based)
Light-O-Rama (LOR) to SPI
Light-O-Rama (LOR)
(USA Based)
PIXEL Extenders
  • ECG-PPX
  • ECG-PPD-A – Powered Pixel Driver - 7VDC – 12VDC input range
  • ECG-PPD-B – Powered Pixel Driver - 7VDC – 40VDC input range
  • ECG-PPD-C – 4 Channel Powered Pixel Driver - 7VDC – 40VDC input range on Channel 1
  • ECG-PPR-A – Multi-Mode Powered Pixel Receiver
  • ECG-PPI-A – Powered Pixel Injector - 7VDC-40VDC Input, 5VDC 1.5A output
E1.31 Bridges and DMX Dongles
DIYLEDEXPRESS
RPM
Discussion Thread
USB to DMX512 Output
FTDI drivers for dongles:
DC Controller Comparison Table
Audiolight Intl HD-714 US China Yes 12V - 24V 3 2A 6A DMX $8.95 $2.98
Audiolight Intl HD-712 US China Yes 12V - 24V 27 1A 15A DMX $44.21 $1.64
Leynew LN-DMXMODEL-3CH-LV12 US China Yes 12V 3 2A 6A DMX $7.49 $2.49
DIYLEDExpress Ren24DC Built or Kit 5,7-24vdc 24 4A 30A x 2 RS232/485, DMX $72.10 $3
DM103 Ray Wu DMX to 3 Channel
Different Styles of Pixels
Waterproofing Pixels
Null Pixels
