10W-RGB-LED-DRIVER
Revision as of 01:06, 17 January 2015 by Ukewarrior (talk | contribs) (Schematic)
Version G2
Version G2
As a separate LED driving power source is applied to the board, three additional connections are made to the board that can control the brightness of each color separately. These connections are typically the 5V DC output pins from a microcontroller.
10W RGB LED
small
small
Color: RGB
Beam Angel: 140 degrees
Life span: >50,000 hours
Version G2
Version G2
BOM for 12V DC power input:
QTY    Board ID           Description
3      IC1,IC2,IC3        PT4115 by Powtech: 30V, 1.2A Step-down High Brightness LED Driver with 5000:1 Dimming
3      L1,L2,L3           100uH Inductor, 6x8mm, 500ma
3      T1,T2,T3           Transistor  FJN3314R
3      D1,D2,D3           Diode    1N5819
Assembly Tips
Version G2
Version G2
Mounting the LED:
Soldering Sequence
After that, simply follow the typical sequence of lowest to tallest components. Do the resistors, the diodes, the transistors, the capacitors, the inductors and finally the LED.
Wiring examples
Note !! This section is under assembly and will be greatly expanded
General Notes
REN48LSD connections
click on the picture for a larger version of the REN48LSD hookup diagram
Installation examples
click on the picture for a larger version of installation in a 10W Flood housing
Where can I get one of these wonderful boards?
He has allowed group buys from time to time on DIYC.
Where there is no group buy in progress, you can usually get this board in a full DIY kit at Rob's tindie store. His store can be found at: [1]
