Ren64TW
Ren64TW - in development.
- The Ren64TW is a 64 channel board, using external SSRs. It has an on board power supply, and optional XBee support.
- This board is currently in development by J. Bolding (bolwire). An initial run of 10 pcbs has been ordered for testing and verification.
The Board
- The board measurement is 5.825"W X 5.500"H, and the provided mounting holes are placed to align with a CG-1500 demarcation enclosure.
Board Availability
- The Ren64TW is currently under development and not available at this time.
Bill of Materials
| PART NUMBER  (Mouser PN#)  |
QTY | REF | NOMENCLATURE |
| 534-3517 | 2 | F1 | Fuse Clips PC FUSE CLIP 5 MM |
| 534-3527C | 1 | F1 | Vinyl Fuse Cover |
F1	504-GMA-1-1/2 	Cartridge Fuses 250VAC 1.5A Fast Acting 	1
D1-4	511-1N5817 	Diode  Vr/20V Io/1A 	4
U1	511-LF50CV 	5V Regulator LDO 1A	1
R1-2	291-750-RC	Resistor - 750ohms ¼ W 5% 	2
R3	291-120-RC	Resistor – 120ohms ¼ W 5% 	1
R4, R7	299-1K-RC	Resistor – 1K ohms 1/8 W 5% 	2
R5, R8-9	299-27K-RC	Resistor – 27k ohms 1/8 W 5% 	3
R6, R10	299-680-RC	Resistor – 680 ohms 1/8 W 5% 	2
R11	299-33-RC 	Resistor – 33 ohms 1/8 W 5%	1
RN1	264-330-RC	Resistor Network 6 pin 330 ohm 1/8 w 2%	1
TF1	838-3FS-412 	Power Transformer 12.6VAC CT 6.0VA Single Primary 	1
	571-7969492	Power Terminal	1
D5	78-1N5229B	Diode, Zener 4.3V .5W	1
D6	78-1N5239B	Diode, Zener 9.1V .5W	1
D7	78-1N5226B 	Diode, Zener 3.3V .5W	1
U14	511-L4931CZ33-AP 	LDO Voltage Regulators 3.3V 0.25A Positive 	1
U6-13	571-1-390261-3	14 Pin IC Socket	8
U4-5	571-1-390261-2	8 Pin IC Socket	2
U2	571-1-390261-1	6 Pin IC Socket	1
J1-2, Ports	571-5556416-1	RJ 45 Top Entry	19
JDP1	649-10090099-S094VLF	DB 9 Right Angle	1
U3	815-ACH-18.432-EK	Oscillator	1
U4-5	511-ST485BN	ST485BN	2
PWR	604-WP710A10IT	Power LED – Red	1
TEST LEDS	604-WP710A10GT	Test LED – Green	6
U2	782-H11AA1	Transistor Output Optocouplers Bi-Directional Input 	1
C1	140-REA332M1CBK1325P	Aluminum Electrolytic Capacitors - Leaded 16V 3300uF 20% 12.5x25mm	1
C2	140-REA470M1CBK0511P	Aluminum Electrolytic Capacitors - Leaded 16V 47uF 20% 5x11 mm 	1
C3-11	80-C322C104K5R	Multilayer Ceramic Capacitors MLCC - Leaded 50volts 0.1uF 10% X7R 	9
U6-13	579-PIC16F688-I/P	8-bit Microcontrollers - MCU 7KB 256 RAM 12 I/O 	8
JP1-2	538-22-03-2021	Header 2P	4
JP3-4	538-22-03-2031 	Header 3P	2
	151-8000-E	2 POS Shunt	6
	532-577102B00	Heatsink	1
Xbee	M22-7131042	Xbee header	2
